YB Plenum spacers
Old Mar 20, 2012 | 06:12 PM
Billy_RS's Avatar
Billy_RS
Default YB Plenum spacers
Ive seen a few for sale. A few different thickness' 10mm, 14mm, 16mm etc
Im aiming for a punchy 380-400bhp and want to know which is the best option?
Cheers Billy
Old Mar 20, 2012 | 06:21 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
I thought all standard inlets were fine up to 400bhp??
Old Mar 20, 2012 | 06:33 PM
gibbo frst's Avatar
gibbo frst
i think the 14mm one is the one to go for.. i have a 10mm one and was a fucker as had to make the fuel rail fit by grinding the lugs down.. think the 14mm one the rail just fits the other side of the mounting lugs..
Old Mar 20, 2012 | 06:50 PM
Billy_RS's Avatar
Billy_RS
Good shout mate, cheers
Old Mar 20, 2012 | 06:57 PM
Rsmat's Avatar
Rsmat
I'd also like to hear info on these.
Old Mar 20, 2012 | 10:52 PM
Hoogi's Avatar
Hoogi
Me too....................especially the fuel rail situation.
Think that's whats always put me off.
Old Mar 21, 2012 | 08:36 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Actually its the 16mm that fits correctly if you measure the lug.
Old Mar 21, 2012 | 08:54 AM
gibbo frst's Avatar
gibbo frst
ok cool... i did mine years ago and all i remembered seeing were the 10 and 14mm ones.. i also drilled the threads out on the manifold part so that i could nut and bolt it as thought it would clamp the whole thing tighter now using the 2 gaskets and spacer..
Old Mar 21, 2012 | 09:06 AM
James @ M Developments.'s Avatar
we find 14mm spacer and two cometic style gaskets fit just right.
Old Mar 21, 2012 | 09:17 AM
Billy_RS's Avatar
Billy_RS
Does the thickness affect lag if using a t34?
Really looking for the car to be punchy
Old Mar 21, 2012 | 09:19 AM
Rsmat's Avatar
Rsmat
Interesting....
Old Mar 21, 2012 | 09:25 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
a 4x4 cossie plenum and escort cossie BT an ST cover are 10 mm deeper than a 2wd
Old Mar 21, 2012 | 11:02 AM
R4N SS's Avatar
R4N SS
thats what ive gone for
Old Mar 21, 2012 | 11:12 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
+1
Old Mar 21, 2012 | 11:20 AM
Rsmat's Avatar
Rsmat
So could I simply bolt a 4x4 cover to my 2wd plenum..?... And gain the 10mm..?
Old Mar 21, 2012 | 11:50 AM
v man's Avatar
v man
Zee Germans are coming
billy you need a 4x4 plenum to start with mate or as said a small escort cos one
Old Mar 21, 2012 | 11:55 AM
fraser9764's Avatar
fraser9764
No, small turbo escort cover.
Not sure on the differences between 2wd and 4x4 inlet runners though?
Old Mar 21, 2012 | 11:57 AM
Stu @ M Developments's Avatar
PassionFords Creator
You forgot to measure the new gaskets Rodders.
Old Mar 21, 2012 | 12:01 PM
Billy_RS's Avatar
Billy_RS
So you need to have a 4x4 inlet with a 14mm spacer?
Old Mar 21, 2012 | 12:15 PM
R4N SS's Avatar
R4N SS
i had 400bhp on a std 2wd inlet
Old Mar 21, 2012 | 12:32 PM
funkyboozer's Avatar
funkyboozer
As RAN above, i too had over 400bhp on a standard 2wd plenum. I did fit a 10mm spacer too but you have to file down two little lumps on the other side of the fuel rail mounting points.
As for changing to a 4wd plenum, dont forget the 2wd and 4wd have different fuel rail mounting points.
Old Mar 21, 2012 | 12:38 PM
R4N SS's Avatar
R4N SS
if you already have a 2wd plenum, just get a spacer and mod the restriction out of the elbow
Old Mar 21, 2012 | 12:47 PM
Billy_RS's Avatar
Billy_RS
Sweet. What size spacer though? 14mm?
Old Mar 21, 2012 | 12:52 PM
R4N SS's Avatar
R4N SS
yep, 14mm - it was whatever the group buy we had on here
Old Mar 21, 2012 | 01:08 PM
Turbosystems
Super Moderator
was that on a PF approved DD rolling road
Old Mar 21, 2012 | 01:48 PM
R4N SS's Avatar
R4N SS
You'll have to ask jimbo as the graphs i was given was from them
Old Mar 21, 2012 | 02:01 PM
Turbosystems
Super Moderator
Think how much power you would have had with the correct plenum
Old Mar 21, 2012 | 02:24 PM
R4N SS's Avatar
R4N SS
only on engine dyno tony - i have heard hub dynos dont count
Old Mar 22, 2012 | 09:02 PM
Billy_RS's Avatar
Billy_RS
Next question is.... who sells the 14mm spacer?
I can find 10mm and 16mm on eBay.... no 14mm's
Old Mar 22, 2012 | 09:06 PM
Rsmat's Avatar
Rsmat
MSD don't they..?
Old Mar 22, 2012 | 09:38 PM
Billy_RS's Avatar
Billy_RS
Cant find them on the website?
Old Mar 23, 2012 | 09:11 AM
We are out of stock, but the new ones should be here very soon,
Feel free to pre order one on the phone! you can even use spring2012 discount to get 5% off!
Old Mar 23, 2012 | 09:42 AM
Billy_RS's Avatar
Billy_RS
Will do. Cheers
Old Mar 23, 2012 | 07:17 PM
Ridgey's Avatar
Ridgey
Only 5% discount, surely you can do better then that
Old Mar 23, 2012 | 07:30 PM
rs2klee's Avatar
rs2klee
K***LMT
got the 14mm on mine with the complete 4x4 inlet setup, seems ok, as tested by James @ MSD
steve.rst
Mar 15, 2016 08:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
mondeomark
Sep 28, 2015 06:28 AM
IainRS1700T
Sep 25, 2015 06:44 AM
timsrs
22
Sep 24, 2015 08:14 PM
