VW Polo problem.....
Old Mar 20, 2012 | 09:29 AM
cfoster's Avatar
cfoster
Default VW Polo problem.....
A friend at work's daughter has gone and bought an 02 plate VW Polo 1.2 (60k on clock). However after having it delivered after driving it she's noticed the oil pressure light come on but only when the car is crawling / going slow. When going normal speed / fast the light stays off. The light is illuminating red when coming on. Could this be a dodgy oil pump? Anything else it could be?
Cheers!
Old Mar 20, 2012 | 12:55 PM
matthart's Avatar
matthart
A friend had one of these and it was just total trouble.
Having changed the pressure sender and oil pump it was finally diagnosed as the timing belt tensioner had gone and the belt had jumped a tooth.
I have no idea how these are related to the oil, but a new tensioner and belt and a re-timing certainly fixed it
Old Mar 20, 2012 | 08:02 PM
cabriolet's Avatar
cabriolet
they are bloody fussy about oil level fella
Old Mar 20, 2012 | 08:07 PM
LHD220Turbo's Avatar
LHD220Turbo
at idle or crawling the revs are low, if the oil light goes out with revs it could be a oil pump/ pressure problem.
Old Mar 20, 2012 | 08:14 PM
Weeksy's Avatar
Weeksy
Change the oil press switch first nose. That light comes on at 7 psi or something, and I am sure at low engine speed that would knocking a treat if there was a real pressure problem!
If it came from a garage I would speak to them to see if they will sort?
Old Mar 20, 2012 | 09:53 PM
cfoster's Avatar
cfoster
cheers chaps wil pass the info on, he did say that the garage she bought it from are going to take a look at it, he's just worried they will take the bulb out the dash!!!!
Old Mar 20, 2012 | 11:03 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
these LOVE jumping timing chains, done many many of them
as said change switch and do oil and filter change, filters collapse and cause pressure problems
T28 RST
41
May 31, 2006 04:43 PM
T28 RST
29
May 28, 2006 09:06 AM
T28 RST
42
May 27, 2006 12:00 AM
mazsco
Oct 2, 2005 06:00 PM
jomarcoz
11
Jun 22, 2004 07:13 PM
