mondeo going in to limp mode
Old Mar 20, 2012 | 07:48 AM
devilboy666's Avatar
devilboy666
Default mondeo going in to limp mode
ive now got the fault code witch is p0251 witch could be a number of things has anyone one had this code and changed anything thanks.
Old Mar 21, 2012 | 10:45 AM
B19 JUB's Avatar
B19 JUB
that code is normally stored with p1211.inlet metering valve failure on the pump.sometimes its actually the valve but 9 out of 10 times the pump has failed which knackered your injectors as i put in your other thread
Old Mar 21, 2012 | 11:28 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
It could be a large number of things unfortunately from the cheap to the eye wateringly expensive. From that fault code alone no one can definitively diagnose it so you either fit parts at random until you succeed (bad idea), or take it to a Delphi specialist NOT a Ford dealer for a proper diagnosis.
Old Mar 21, 2012 | 01:01 PM
sexy xr2i's Avatar
sexy xr2i
is ur car petrol??? x
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
