do injectors need recoding.
Old Mar 19, 2012 | 09:03 PM
devilboy666's Avatar
devilboy666
Default do injectors need recoding.
do injectors need re-coding if you get then reconned and if so does anyone no who does them and how much.
Old Mar 19, 2012 | 09:11 PM
rs-tuner's Avatar
rs-tuner
For a diesel yes.
Old Mar 19, 2012 | 09:12 PM
RsS2daz's Avatar
RsS2daz
Hi mate, if your on about common rail diesel injectors, i do them at work, i work for colchester fuel injection ltd, we overhaul Delphi and Bosch , i mainly do Delphi, which once finished through a full test after overhaul they get a new 16 digit c2i code, overhauls are 118+ vat each
www.colfuel.co.uk
cheers daryl
Old Mar 21, 2012 | 07:16 PM
andrewg's Avatar
andrewg
Most of the time you get away with it
Very rare they will not start
Somtimes a bit rough
After few drive cycles the ecu monitors cylinder balance and will adjust accordingly
andrewg's Avatar
andrewg
It's for emissions not security
Old Mar 21, 2012 | 11:12 PM
M K's Avatar
M K
www.colfuel.co.uk
cheers daryl
What is the surcharge on posting out replacement recon ones before i post mine back to you?
I phoned your place and got a quote of £118 + vat but ideally i would like the replacement recon ones here before i take mine out to save a lot of hassle getting a lift to colchester
Also how do i identify what type i have? i was told there is a few? i have all the parts numbers off of each injector and each code if that helps
For example
CYLINDER 1 INJECTOR =
7C297B10A528C7E6
E2U9A
357Q-9K546-BB
EJDR00501Z
0760LW15F42
Thanks
Marc
Old Mar 22, 2012 | 10:02 AM
M K's Avatar
M K
Spoke to Daniel at col fuel this morning and ordered my 2 replacement injectors
They deliver to your door too
It is safe to say that 2 of mine are definitely f*cked
I get the code, fuel pressure about or below desired
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
