3dr idling
Hi all, just saying I am sick to death of my 3dr not idling properly, so am asking wot does everyone's 3 drs idle at ??? Mines sometimes 500rpm then 800rpm and sometimes 1000rpm and it mostly stalls it has standalone management on it but it's a pain in the arse is it the map or has anyone eles had this problem wots turned out to be something silly!! Wud a car wots bee mapped fluctuate on idle? I thought it might be like it all the time..... please help as its spoiling my fun
Yes !!! If I give it a blast and let the revs fall naturally to idle it will stall and then is a twat to start I talking turning over for about 6-7 seconds with a bit of throttle to start it again it's embarrassing .
No not at all, sounds like you have a problem, whats the co like as might be a bit rich, but as you don't have standard management don't have a clue how to fault find it. Who mapped it as go back to them to check it over
I must admit wen I bought it, it was already mapped and setup and I flagged down these problems but they just don't seem interested at all but it's going back down on the 14th because I've had enough I just wanted some ammunition to throw at him by saying no one eles do it it's sooooo bloody annoying I once came up to a roundabout and it died and I couldn't get it started again ! Why wud te idle fluctuate thought it wud stay at whatever it's been mapped too ???
The correct (official) speed is 850 RPM.
Don't know why everyone seems to have missed this but 500 RPM is no good what so ever and will cause the stalling you are having, it can also cause a bad idle as the ECU senses it's to low and will compensate via the ISCV.
No problems starting here what so ever, bearing in mind mine is rarely ever used, it always starts first time, again your idle isn't going to help this!
Setup the base idle properly, you should find this will sort most if not all of your issues!
Martin
Martin
Don't know why everyone seems to have missed this but 500 RPM is no good what so ever and will cause the stallinYg you are having, it can also cause a bad idle as the ECU senses it's to low and will compensate via the ISCV.
Martin
Martin
The driving issues won't be down to the idle.
Quite frankly if the mapper gave the car back to you lke that, then his no mapper anymore than I am the pope!
Out of interest what made you decide to change management, the OE Weber ECU'S are very good!
The starting quite possibly is down to the idle, the way to tell is to open the throttle slightly when starting, what happens?
Martin
Martin
Martin
Martin
For example on a cold start MAP you might have a temperature range and then a fuelling table which says for xx °c give an injector pulse for x milliseconds, I have put this simply there is alot more that goes to actually achieve what it does.
So if it is poorly mapped (not saying it is) it will simply act on what the MAP says, you can now understand why it's very dangerous for someone to play with maps unless they are 100% compentant in what they are doing, especially with a FI engine as with boost you can end up with a meltdown very easily.
With adaptive ECU's they will make slight corrections where they can and store those in memory for optimum running conditions.
If you have a MAF sensor then you also have aftermarket sensors, as these cars have MAP's.
Back on subject like I say, set the base idle correctly as that is far to low!
That cannot bve right what they are saying re the ECU, thats a basic function of any ECU or car infact for it to start!
Martin
