Xenon head lights
Old Mar 14, 2012 | 01:25 PM
Hodgie333's Avatar
Hodgie333
Default Xenon head lights
Hi all
Can anybody tell me how much it will cost to get xenons fitted to my focus st170
At a garage
What would I be looking at to pay
It a 2004 model
Hodgie
Old Mar 14, 2012 | 04:34 PM
If your getting xenons fitted you will need the front bumper with the washer jets in cause the car wont pass an mot without the washers.
Old Mar 14, 2012 | 11:54 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
New MOT rules say that a car MAY have headlamp cleaning system and/or self levelling headlamps or suspension if it has HIDs and if fitted, they must work. It does NOT say it MUST have them fitted. So you don't have to have washers or self levelling.
Old Mar 15, 2012 | 05:10 AM
Ok i will shut up then lol.
Old Mar 15, 2012 | 06:48 AM
Hodgie333's Avatar
Hodgie333
Thanks
All
Very good advise never thought it would affect the mot good job it's people like you who know
Regards
Hodgie333
Old Mar 15, 2012 | 08:49 AM
Oranoco's Avatar
Oranoco
I have used this exact quote myself. I gather however that the rules are due to alter again in April
Old Mar 15, 2012 | 08:52 AM
STeve's Avatar
Super Moderator
ST170s have adjustable electrical hieght motors in the lights, Just dont go silly on brightness around 5000k should do the trick
Old Mar 15, 2012 | 08:54 AM
RichieST's Avatar
RichieST
I'm under the impression that the MOT rules are changing to make the aftermarket kits illegal, however if you fit a proper xenon headlamp unit then all is good.
The levelling of the factory units might not work though unless you fit the front / rear adjusters and relevant wiring on the suspension arms.
Old Mar 15, 2012 | 08:55 AM
Oranoco's Avatar
Oranoco
5000k has nothing to do with brightness, it's simply the colour temp.
35w kit around 4300k to 6000k max and only fit to Projector type lense units.
Old Mar 15, 2012 | 09:15 AM
STeve's Avatar
Super Moderator
Department for Transport (DoT) wrote:It is not acceptable to convert a headlamp approved for use with a halogen filament bulb to use a Xenon gas discharge bulb. In our opinion the only acceptable way to convert a vehicle to use Xenon headlamps is to replace the entire headlamp unit for one which has been approved for use with gas discharge bulbs. Such headlamps will be approved to UNECE Regulations 98 and 'E' marked to show compliance
Our main concern is for the potential for modified headlamps to produce an dincorrect beam pattern and to cause glare to other road users. Halogen headlamps are designed to produce a defined beam pattern using a filament wire with a shape and dimensions which are tightly controlled by regulations. A gas discharge bulb produces an electrical discharge which has a very different shape and dimensions to a filament wire adn so the beam pattern produced will be incorrect
If headlamps approved to UNECE regulation 98 are retro fitted to a vehicle then they must be self levelling (either as part of the headlamp unit or some vehicles have self levelling suspension which is adequate) and headlamp washers must be installed.
Old Mar 15, 2012 | 09:47 AM
Oranoco's Avatar
Oranoco
That has been the case for ages so nothing new in there. It's another case of the MoT regs not mirroring the law.
Old Mar 15, 2012 | 09:49 AM
STeve's Avatar
Super Moderator
true most MOT stations I know will pass it anyway as long as the rest of the car is sound
Old Mar 15, 2012 | 10:12 AM
RichieST's Avatar
RichieST
At the moment it's only a fail if there is no beam pattern. I had one of these HID kits a few years back and they failed.
Old Mar 15, 2012 | 11:38 AM
STeve's Avatar
Super Moderator
if its OE equip then I have no issues but way too many cheap and nasty non beam pattern types installed as well as all these poxy DLR lights on cars, are folk really that blind
yatta
May 21, 2016 10:31 PM
fuzzy
Sep 4, 2015 10:11 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
