abs light
Old Mar 11, 2012 | 11:24 AM
turbo1973's Avatar
turbo1973
Default abs light
my abs light has come on on my van i hit a pot hole a couple of hours before light came on so dont know if that caused it i got the light checked which was showing rear wheel right so got light switched off and it stayed off for a week but is back on again is it the sensor thats faulty or what else can cause this
Old Mar 11, 2012 | 02:27 PM
cabriolet's Avatar
cabriolet
get it read again fella wouldnt b at all surprised if it didnt fuck the sensor in the pothole
Old Mar 11, 2012 | 02:55 PM
GVK.'s Avatar
GVK.
Could be sensor, could be a wiring fault.
What van is it?
Old Mar 11, 2012 | 03:12 PM
turbo1973's Avatar
turbo1973
2008 fiat scudo
Old Mar 11, 2012 | 03:45 PM
GVK.'s Avatar
GVK.
I have done a couple of Fiats in the last year or so at work with ABS faults, and both times they have had the wiring corrode inside the insulation. On a Doblo van I had to pull the loom from the rear sensor, all the way back to the connection at the A pillar (had hi-resistance in the rear loom from the connector) and take off all the insulation all the way along and check the wire. Someone else had fitted a sensor and it still had the same fault.
Once I'd taken the braiding and tape off to expose the wires themselves, I found a cut in the wire, about 12" from the rear sensor connection. It had gone green with corrosion and snapped in my fingers.
I think when the looms are made they are in a jig with 'claws' to locate the loom on the jig, when the loom is pulled about, it can nick the insulation, and even though it's all taped up, moisture gets in there eventually and corrodes the wires.
In my experience, if the sensor has failed it will bring the light on as soon as you drive it.
My advice would be to get the sensor loom checked properly before just banging a sensor on it.
Old Mar 21, 2012 | 05:24 PM
turbo1973's Avatar
turbo1973
this was the fault
Old Mar 21, 2012 | 05:52 PM
GVK.'s Avatar
GVK.
Good old Fiat wiring!
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
