toyota supra differential identification ???
Old Nov 13, 2011 | 03:59 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
Default toyota supra differential identification ???
is there any sites out there that can tell me what specific ratios the various supra models came equipped with ?
also are the na and tubby versions the same 8 inch lsd units ?
are they all lsd equipped ?
anyone shed some light , make my life eaiser when i pop down to my local jap breakers ,
beef
Old Nov 14, 2011 | 05:38 AM
-beefy-'s Avatar
-beefy-
anyone , bump for the morning crew
Old Nov 18, 2011 | 02:53 AM
TRUEBLUE1968's Avatar
TRUEBLUE1968
Normally Aspirated - 4.30:1
2.5 Twin Turbos - 4.10:1
3L Turbos (87-88) - 3.90:1
3L Turbos (88-92) - 3.73:1
TRUEBLUE1968
BTW in the States these are the MKIII
Old Nov 18, 2011 | 04:13 AM
lee2cossies's Avatar
lee2cossies
Im going to go down this route so need this info too! How much do these diffs go for and which model is closest to the standard Cossie diff ratio?
Old Nov 19, 2011 | 11:11 AM
-beefy-'s Avatar
-beefy-
stock 2wd cossie is 3.54 mate
Old Nov 19, 2011 | 11:28 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Its 3.62 (or 3.64) can never remember which way round 2wd and 4x4 ratios go!
Old Nov 20, 2011 | 08:19 PM
2wd's Avatar
2wd
3,64 are 2wd .... and 4wd are ...
Also I'm interested in these Supra diff's ...... so if anyone could explain about what is needed and what needs to be modded and about costs .. please let me know as I'm cant handle anymore diff problems :-(
Old Nov 20, 2011 | 08:24 PM
Martin-Hadland
Not that it makes a lot of difference!
Old Dec 11, 2011 | 11:19 PM
janvanv's Avatar
janvanv
www.rallyanarchy.com
The Supra diff which we have been using over here where we never got a LSD in our cars is the 87-93 MkIII Supra which is properly called "MA70".
It looks like this:
In North America the ratios aew:
3L Turbos (87-88) - 3.90:1.................manual box
3L Turbos (88-92) - 3.73:1 ...............manual box
3l Turbo (87-93)...4.3:1..................autotragic slush box
3.0 n.a. (87-92)....4.3:1................all, and LSD with the "touring package"
The mounting kit is USD300, and to bolt up the propshaft there is a companion flange for around USD85 and a weld-in yoke ---the other half of the u-joint for around USD18-19
The u-joint is a Spicer 1310 available everywhere, here it is maybe USD20.
In North America we got only 3.64 open diffs for 5 speed XR4Ti and Scorp V6 (all), and 3.36 for XR4Ti (commonly referred to here as 'Xratty' cause the 4 looks like an 'A') with the horrible C3 autotragique.
I started doing these kits cause we want the 4.3 ratio for gravel rally but it turns out that when people bin the Type 9 Ford box and use Borg Warner T5, that all the USA T5s come with such tall 5th that the 4.3 is pretty good even on road cars when the 5th is 0.72 or 0.63.
So now we have a car that rips hard 1st thru 4th and use the 5th for highway cruise.
Top gear OVERALL with a 0.82 top and 3.64 is 2.98:1
with a 4.3 and a .73 is................................3.14:1
with a 3.9 and a .73 top is...........................2.84:1
Even the 4.3 with the nuts overdrive of .73 is only 5% shorter than original.
4.3 with the 0.63 is overall 2.7:1 9% taller than original.
Old Dec 11, 2011 | 11:25 PM
janvanv's Avatar
janvanv
Du kan skicka mig e-majl eller PM, men bäst är direkt e-post
och addressen är janvanvurpa PÅ gmail (punkt) com.
Jag läser danska även om det är svårt som fan att förstår vad fan ni säger.
Engelska går bra också.
Ibland
mgtkr1
107
Dec 6, 2016 04:23 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mint_s2
Sep 2, 2015 08:58 AM
gjh
Aug 5, 2015 04:21 PM
COLEYST200
Aug 3, 2015 08:55 AM
