General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
pedals look a bit iffy, and it would really need the abs fitting to make me comfortable with it, but otherwise it's a fairly tidy example, and a lot of car for the money
Abs fitting to be comfortable ?
My good you come out with some shit. It's a 25+ year old car. WTF it need abs for ?
Nice looking 3door , You can get them to run if you use the lot, but it says a new ecu and rewire,that's prob an aftermarket or boa one. Why is abs a bad idea ?
if he's fitted cossie brakes and stuff, and rewired it, the least he could have done was sorted the abs out, after all, it's only a stand alone loom, and much better than the standard base spec servo and stuff that seems to have been there from the start
also, it doesn't need to be an aftermatket unit as the bob will run from the boa loom, you just need to figure out a way to fire the secondary throttle things
I agree on the abs mate I fitted it in mine , not driven it yet and tested it. I don't get why people think its a bad thing? Yep as I said the boa is the cheaper ecu and a rpm window switch can be used. On Fordpower they have managed to get a bob running with a mondeo 24v ecu the maps are very close.
