3.9 diffs
Old Nov 8, 2011 | 08:42 PM
boost mad's Avatar
boost mad
Default 3.9 diffs
How much difference do the actualy make?
4x4 saph cossie, bout 450/460bhp
Old Nov 8, 2011 | 10:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
much better acceleration but limited top end
also need to have one of them plates on the front
possible 2nd gear launches if you are brave
Old Nov 8, 2011 | 10:13 PM
james kiely's Avatar
james kiely
what speed do they top out at dojj?
Old Nov 9, 2011 | 09:55 AM
boost mad's Avatar
boost mad
is it worth the swap though?
would be done with standard ratio front diff and drop gear in transfer box.
Old Nov 9, 2011 | 10:22 AM
pieterjan's Avatar
pieterjan
My mate has them on his cosworth he is running approx 380bhp and you have better acceleration. I think it's a good upgrade for the car.
Old Nov 9, 2011 | 10:57 AM
boost mad's Avatar
boost mad
is it not going to be alittle short gearing for the power though?
Old Nov 9, 2011 | 10:58 AM
JonnyBravo's Avatar
JonnyBravo
Rainbird runs 3.9's from memory. Best mod my mate ever did to his 3 door.
TiB off here still managed 178mph at Brunters running a 3.9.
I wouldn't say they are too bad on the road, just the cruising speed needs to be more like 70 not the 80+ that your maybe used too.
Old Nov 9, 2011 | 11:00 AM
boost mad's Avatar
boost mad
what sort of increase in rpm is there at 70mph over the standard?
Old Nov 9, 2011 | 12:21 PM
JonnyBravo's Avatar
JonnyBravo
Ask Mike, I'm quite sure my mates was doing something around 4k @ 70mph but dont take my word on that
Old Nov 9, 2011 | 06:11 PM
dojj's Avatar
dojj
the standard one is 3.62:1 so the "upgrade" to the 3.92:1 is only 1 less tooth on the pinion drive with 14 instead of 15 or something along those lines
it's "easier" to put the power down with less gears to turn and, in essence, makes your car "feel" more powerful without actually adding any more power to it
Old Nov 9, 2011 | 06:21 PM
Porkie's Avatar
Porkie
Was one of the best mods I did to my old 4x4 door.
Old Nov 9, 2011 | 06:23 PM
Porkie's Avatar
Porkie
No
You can still do over 180mph at brunters. My Sierra did it...
The speed limit on road is 70mph. The fastest you will go on any racetrack is what 150mph?
so what more you need?
Old Nov 9, 2011 | 07:19 PM
JonnyBravo's Avatar
JonnyBravo
Originally Posted by Porkie
No
Summed up perfectly.
Old Nov 9, 2011 | 09:36 PM
boost mad's Avatar
boost mad
No
I didnt mean so much top speed, i ment going through the gears. If that makes sense
Old Nov 10, 2011 | 07:00 AM
Porkie's Avatar
Porkie
Steve Scott summed it up better. He said to me '3.9 gearing makes em sparkle'
Old Nov 10, 2011 | 07:51 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Love this subject but as always things are not what you think.
The Sierra left Ford with 205/50/15 tyres giving = 23.7mph/1000rpm
Every Tom, Dick & his Harry then fit :
225/40/17 = 24.75mph/1000rpm or 225/40/18 = 25.77mph/1000rpm if you change the Diff to 3.9 on the 225/40/18 = 23.92mph/1000rpm so you need the 3.9 to get it back to standard gearing.
The correct gearing is the shortest gearing that will give you grip no point fitting a 3.9 on mine it would spin its wheels at alltimes everywhere .
The shortest i can go is 3.54 diff with 235/40/18 = 25.72mph/1000rpm.
You can indeed reach 180mph at Brunters with a 3.9 provided the Tyres selected allow you to reach 180mph at roundabout max power.
Old Nov 10, 2011 | 08:26 AM
Porkie's Avatar
Porkie
Didnt think of that Rod.
Good point!
Old Nov 10, 2011 | 08:40 AM
KSA-Cossie's Avatar
KSA-Cossie
How much though for front and rear diffs plus the alteration to the box ?
Old Nov 10, 2011 | 08:41 AM
KSA-Cossie's Avatar
KSA-Cossie
And actually finding the 3.9 stuff
Old Nov 10, 2011 | 09:00 AM
Mark RS's Avatar
Mark RS
ive just done it to mine.there is guys in northern ireland that have new and 2nd hand 3.9 cwp on the shelf.
not dricen it yet as im waiting on my fuel tank back.
Old Nov 10, 2011 | 09:48 AM
robrs2's Avatar
robrs2
I've got a 3.92 front and 7" 3.92 LSD rear diffs for sale
Old Nov 11, 2011 | 08:27 AM
dojj's Avatar
dojj
i think i've got a few 3.92 front diffs in the garage
as for 3.92 rears, find any dohc rwd sierra 90/92 spec and you've got one (as they were fitted with the 7.5" 3.92:1 diff as standard
Old Nov 11, 2011 | 08:43 AM
Gary F's Avatar
Gary F
I'd like to go this way with mine too. So you need both diffs and the gearbox modded? How much would it cost?
Old Nov 11, 2011 | 09:00 AM
dojj's Avatar
dojj
if you can find a dohc 4x4 sierra then the diffs are a direct swap, buy the car, swap the diffs, sell the car
you only need to do the gearbox mod if you change the front OR rear diff as it's the step down gearing to keep the centre diff spinning at the correct speed
Old Nov 11, 2011 | 09:19 AM
Gary F's Avatar
Gary F
Oh so if I buy front and rear diffs then no need to touch the gearbox?
Chances of finding an old Sierra now are thin on the ground, is they no one that just sells them?
Old Nov 11, 2011 | 11:47 AM
dojj's Avatar
dojj
ebay throws up a few for around the Ł500 mark occasionally
http://www.ebay.co.uk/itm/ford-sierr...item3cbe2448ff
this one though is a bit much
Old Nov 11, 2011 | 01:08 PM
Gary F's Avatar
Gary F
How much Mark?
Old Nov 11, 2011 | 04:05 PM
bigluke200's Avatar
bigluke200
I've fitted a 3.9 to mine (2wd) It deffo makes pottering about and pulling away with an evil clutch nicer than before, the whole car just seems more driver friendly.
Can't comment on performance as haven't had my car on boost much since running it
Hi Rod,
Makes a lot of sense
How would my actual car speed compare to my indicated speed then? I'm runnning a 3.9 diff (2wd) with 235/40/17.
I guess not *too* far out at legal speeds?
Old Nov 15, 2011 | 10:49 AM
M K's Avatar
M K
Does anybody have a 3.9 front and rear crown wheel and pinion for sale?
Is it just the crown wheel that have a different number of teeth? Or the pinion shaft as well?
Thanks
Marc
Old Nov 15, 2011 | 10:54 AM
JonnyBravo's Avatar
JonnyBravo
Both are different afaik
Robrs2 above says he has some for sale.
Old Nov 15, 2011 | 11:19 AM
M K's Avatar
M K
I have pm'd him
Anyone need a newly shot peened and super finished 3.6 rear 7.5" crown wheel and pinion then give me a shout
Old Nov 23, 2011 | 09:44 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
is it worth fitting the 2.0 4x4 box as well as the diffs?
Old Nov 23, 2011 | 10:02 PM
M K's Avatar
M K
No as the cosworth 4x4 mt75 has a thicker main shaft i am told so will be slightly stronger,
Also if you change the front and rear diff to 3.9 ratio then nothing has to be done to the standard cosworth gearbox, you only need the drop gears if you leave the front diff as a 3.6 and change the rear to a 3.9 to make up the difference in rotational speeds
Thanks
Marc
Old Nov 23, 2011 | 10:05 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
had this on my old car and will be getting it again good mod imo...
Old Nov 23, 2011 | 10:12 PM
JonnyBravo's Avatar
JonnyBravo
Long time no see Ben
Old Nov 23, 2011 | 10:44 PM
Gatecrasher
Not welcome...
yeah got my self another money pit hows you, nice pug in your sig whats she running?
Old Nov 24, 2011 | 07:37 AM
JonnyBravo's Avatar
JonnyBravo
Lol, they just have that effect on people don't they! I bet your mikes favourite customer right now lol
I'm good though thanks, gave in with the escort in the end. Doh
The pug runs a pinto with 8 injectors and a t4 making about 450hp
Old Nov 25, 2011 | 01:00 AM
Gatecrasher
Not welcome...
sounds fruity
mike actually keeping quiet at the moment letting me see what i come up with before he shoots me down in flames
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
Fezman1
Sep 7, 2015 09:34 PM
cbminis
Sep 7, 2015 09:42 AM
