Running in oil - discussion
Old Nov 6, 2011 | 11:30 AM
BRAMMER's Avatar
BRAMMER
Default Running in oil - discussion
Think i have got myself confused a little regarding suitable oil for running in - some are saying one and some another.
I want to use a decent enough oil that will do the bedding job fine for the first 500 (then repeat for another 500) but i don't want it to cause any harm at the same time so....
Mineral oil - what actually falls under this category???
Castrol 15w 40 is part synthetic which i was going to use as it's the bottom of their range but not 100% sure as some say no it has to be just plain cheap mineral oil
http://www.halfords.com/webapp/wcs/s...egoryId_165581
Even Halfords own oil is part synthetic, pretty much the whole range
http://www.halfords.com/webapp/wcs/s...ed=fullService
Millers running in oil is roughly £25 delivered from the oilman which isn't overly expensive.
http://www.opieoils.co.uk/p-60229-mi...ng-in-oil.aspx
Carlube do a plain mineral oil but is it good enough to use in an expensive engine?
http://www.diy.com/diy/jsp/bq/nav.js...LAID=266990215
What brand make and rating's have you used
Old Nov 6, 2011 | 11:34 AM
James @ M Developments.'s Avatar
proper running in oil is the best to use if you have the choice,
prevents bore glaze and aids the bedding in process.
Old Nov 6, 2011 | 12:28 PM
tee-rex's Avatar
tee-rex
I have used millers running in oil for years never had any problems with it.
Old Nov 6, 2011 | 03:48 PM
stevieturbo's Avatar
stevieturbo
C**t
A gallon of Millers running in oil should cost around £22 from any local stockist
Old Nov 6, 2011 | 04:05 PM
frayz's Avatar
frayz
Boost Junkie
Ive just finished running my Impreza motor in.
10w 40 Millers running in mineral oil for 50 miles. Drop the oil/filter
Same again for another 450 miles, drop the oil/filter.
At 540 miles i swapped to Motul 300v. Now done 650 miles and mapping for full power this week.
I was running boost through the car and up to 5.5k rpm within 8 miles of start up.
Dont go all softly softly on run in. Give it plenty of load and at very least 0.3 bar boost.
mk22door
49
Mar 26, 2022 07:15 AM
Chas
Sep 21, 2015 08:57 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
