help, fiesta mk4 front strut removal
Old Nov 5, 2011 | 12:09 PM
tommytwotanks's Avatar
tommytwotanks
Default help, fiesta mk4 front strut removal
help, i need to remove the front strut it's almost off, but i cant undo the nut or move/undo the allen nut/screw at the top, when i turn the nut is this undoing anything, the road spring isnt going to go bang/explode, so how do i undo remove the strut safely
thanks
Old Nov 5, 2011 | 04:48 PM
tommytwotanks
thanks
well ive got the strut out and cut away at the suspenion arm, bloody front bolt is seized solid what dream job this is turning in to
Old Nov 5, 2011 | 06:56 PM
martysmartie's Avatar
martysmartie
There will be a nut at the top of the turret, you can safely remove the whole strut, however when removed you will need to have some spring compressors to hold the spring, BEFORE you undo the nut you will see on the top which holds the top plate down.
So if you have it removed from the hut you just need to undo it from the turret?
Use plenty of penetrating oil on the stuck bolt and leave to set first.
Martin
Old Nov 5, 2011 | 07:14 PM
tommytwotanks
Martin
the problem i have now is, ive removed the strut and cut away the lower arm (with a grinder) so that i can get at the siezed front bolt, hopefully useing a blow lamp on the seized bush/bolt to heat it up and freeing it, well that's tomorrow morning's plan, have you got a better idea
Old Nov 6, 2011 | 11:14 AM
martysmartie
You shoulden't have to touch the lower arm, normally it's just a case of levering the lower arm down so the strut can be removed from the hub?
Martin
Old Nov 6, 2011 | 06:21 PM
tommytwotanks
Martin
im not changing the hub, im changing the lower suspenion arm
all sorted now, but what a nightmare, burnt the rubber bush out, then had the grinder on it to cut it in half, managed to lever the front half out after grinding the head of the bolt off, then wacked the rear half out with a 4 lb hammer and a long chisel, i didnt think i was ever going to manage do this, it's been a long day
original
Apr 28, 2026 05:20 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
A.t.p
Aug 15, 2015 11:37 AM
track.focus'd
Aug 12, 2015 05:53 PM
Bosch
Aug 4, 2015 05:14 PM
