Solid beam mounts
Has anyone used these on the back of a 2wd saph cossie?
Not sure what would be better solid mounts or poly, bearing in mind the car will mainly be used on the road.
General feelings is solid is best, ive got them on my 4x4, and in all fairness, i didnt notice any difference in noise/ride quality over poly, but they sharpened it up alot.
they were in it when i bought the cr so not sure on fitting..
They are dead easy to fit, as they come in two halfs! just put therm in place and bolt it up.
we have them on our webshop.
www.shop.motorsport-developments.co.uk
Or does the beam need to come right off?
Ideally you need to take the.beam out as getting the old bushes out is a fookin mission!!! they should really b pressed out!!! if i remember correctly i had to burn mine out in the end
i managed to pop mine out by using the cars weight with a large socket behind the bush, came out easy, otherwise cut them out, burning will work, but keep an extinguisher handy.
New ones are a 2 minuite fit.
here you go:
http://www.shop.motorsport-developme...unction=search
if this link doesnt work just type the word BEAM into the search box.
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
