Fan loom help
Old Oct 30, 2011 | 05:17 PM
BRAMMER's Avatar
BRAMMER
Default Fan loom help
I have a fan loom and has 2 black wires coming off it to connect to the O.E fan switch plug - do the wires have to go a certain way around or not?
Black/red & Brown on the plug
Also the wiring on the plug must have got hot at some point as half of the copper is blackened, is this still fine to use?
Old Oct 30, 2011 | 05:19 PM
ZTSI's Avatar
ZTSI
I would say speck to the guys at CW looms.
They will be able to help you out.
Old Oct 30, 2011 | 07:18 PM
BRAMMER's Avatar
BRAMMER
That's who's it is and it doesn't specify on the instructions
Old Oct 30, 2011 | 07:24 PM
James @ M Developments.'s Avatar
they can go either way chris it just makes a circuit when up to temp.
As for the wiring, yes it should be fine, its only a trigger for the relay,no real current runs through it.
Old Oct 30, 2011 | 07:39 PM
Rsmat's Avatar
Rsmat
+1...
Chris I have a MSD one fitted... I can send you the instructions if you like?
Old Oct 30, 2011 | 07:55 PM
BRAMMER's Avatar
BRAMMER
As long as I know either wire connects then that's sorted I'll solder them in the morning
Old Oct 30, 2011 | 10:23 PM
martysmartie's Avatar
martysmartie
As said re the switch.
Was it standard before? As it could be in the past some numpty has tried to wire the fans via the switch hence the blackness, assuming it's just not corrosion?
But yes it SHOULD only trip the relay, so little draw.
It's also worth uprating the switch as this is what causes half the problem in the first place!
Martin
Old Nov 2, 2011 | 02:54 PM
R4N SS's Avatar
R4N SS
The fan looms come with a new switch
Old Nov 2, 2011 | 08:19 PM
BRAMMER's Avatar
BRAMMER
Not from CW/MSD - the ones from Paul and other places may come with a switch but i'm not sure if it's rated the same as the MSD item
Old Nov 3, 2011 | 07:08 PM
martysmartie
I would hope so, the name is actually a little misleading as there is nothing "Uprated" about it at all, only difference is the span. The original switch belongs in the bin, thats not to be confused with the Ford parts bin it came from either
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
