vw techhies - 1.9tdi bora highline - shorty ect ??
formerly beefy-rst-2
bros just bought a 02 vw bora 1.9 tdi highline ?
turbos shat itself , and hes looking for a repalcement ..
anyone shed any light on the model of the unit on them , best place to get one ect ect ?
not looking to up the power ect , just a useable replacement cheaper the better ?
many thanks
beef
many thanks
beef
rosco , aint seen it yet , but there saying its fucked and half a turbine missing ,
plenty of turbos on the bay , around the 350 mark ,
just worried there cheap cast replacements and fall to bits 1000 mile down the line ,
beef
beef
if you have the PD engine it will be a garrett unit with variable vain. They are prone of breaking if not serviced correctly. If a new unit is fitted you will have to change the oil pipes as most suppliers will not supply the turbo unless you order the pipes. To be honest I have changeed loads of these when I worked at Seat in Darlo. I would try avoid 2nd hand ones. Hope this shed a bit of light on some thing.
Changed loads of these beefy when i worked at vw best bet is to get a recon one from somewhere like midland turbo they are the exact same units as supplied by vag but half the price and come with a two year warranty iirc. Also if the shaft has snapped the chances are the exhaust is full of oil along with the intercooler.My advise is to remove the intercooler and all boost hoses jet wash them all because if you leave them fit the new turbo and start it up they run on there own oil and the engine will go kaboom.As for the exhaust if its full of oil replace it.
There is a place in Stoke that will do you one for Ł300 exchange on a re-con unit.
Other than that it is take your chance on eBay, looking at Ł100 - Ł250 second hand.
I think it is a GT1749, but a different one to the 2.0 one, so check when buying. Your turbo will have a 9 digit number on it probably starting with a 3xx xxx xxx.
I might be wrong as I only know for sure for the 2.0 but I've looked at a lot of turbos for sale and noticed the GT1749 goes on the 1.9 as well as the 2.0
As said likely to be a GT1749v. the part numbers are different depending on age so you many need to get it off it. They all start with 0 if i remember right. Never changed the lines on the one I did just flushed them out was on a sharan. Had a few turbos from AET at resonable price
many thanks
beef
many thanks
beef
Like I said only seen them 04 onwords and they come with them hock type wheels and heated leathers cd player choice either rear center headrest or armrest oh and parking sensors and the highline is actoully comes with a se suspension as are the rear lights of an se as std lol.Basically a cross between a sport and se and st.
Bit of advice mate of mines got a bora 150 tdi and he used castrol edge oil twice service intervals it had a nocking noise as if the bottom ends was gone had it checked from vw turned out to be a nackered cam with a hole in on of the followers cost him Ł400 pounds from a local garage so NEVER USE CASTROL EDG OIL IN A PD ENGINE alwas use vw oil better of as he found out lol.
DixieTheKid
11
Jun 6, 2020 11:20 AM
