Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
Old Knackered 355x32 and 330x32/28 discs
Old Oct 17, 2011 | 11:36 AM
M K's Avatar
M K
Default Old Knackered 355x32 and 330x32/28 discs
I am in the process of dummy fitting my fiesta cosworth suspension and flanges etc and I am using the wrc bells on the front that take the 355x32mm discs with a 12 bolt/ 248mm pcd, I am after a pair of cracked and damaged and good for the bin etc discs as it's only for trial fitting and checking clearance then they will go in the bin, I just can't really afford to lay out £500+ on new discs right now that arent actually needed yet and the money is better spent elsewhere you know
I'm also after some 330x28mm or 32mm for the rear with a 12 bolt/ 203.2mm pcd also for dummy fitting so again ones that are good for the bin is all I'm after
Pm me if you have anything laying about
Thanks
Marc
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
SMILER258
Sep 28, 2015 09:04 AM
