AN fitting for FPR
Does anyone know which size male AN / Aeroquip fittings I need to convert my MSD Webcon Fuel regulator. Im ordering all the bits to replace all my fuel pipe and fittings to braided -6 with aeroquip fittings.
This is the FPR
This is the FPR
im just in the middle of doing this ordered a hart inlet and modded my standard fuel rail with to -6 male fittings im also going to mod the standard fuel reg to take aeroquip fittings aswell
Think I will bite the bullet and fit the AN6 teflon stuff.
ill be keeping my standard steel lines and brazing -6 fittings to the ends,that way you need very little braided fuel hose and you can use the original clips to hold it to the floor.
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
