Simple question regarding msd evo chip
Old Sep 29, 2011 | 08:22 PM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Default Simple question regarding msd evo chip
Does my chip need to be modified if I change my boost level?
Simples....
Dan
Old Sep 29, 2011 | 08:49 PM
BRAMMER's Avatar
BRAMMER
I always have mine set by MSD and never change it until my next visit, did they set your car up?
Old Sep 29, 2011 | 09:06 PM
Marc sierra's Avatar
Marc sierra
That depends how much and how you change the boost. If you're just adding a bit of boost by adjusting a bleedvalve it shouldn't need it, as long as you stay belong the boost limit for that chip.
Old Sep 29, 2011 | 09:12 PM
SaphCos4x4_Dan
I don't have a bleed valve, was going to get a local tuner to set it and set the fuelling for me, but wondered if I needed to send my chip to msd to be altered.
I want to go from holding 24 to 30 psi
Old Sep 29, 2011 | 09:24 PM
Marc sierra
I wouldn't know what needs to be set for the fuelling. As long as you only increase the boost and the chip can handle the 30 psi you should be OK. But it's a bit difficult to answer when you don't tell what you current setup is.
Old Sep 29, 2011 | 09:44 PM
SaphCos4x4_Dan
Escos grp A T35 with mar-m, dark greens, 3 bar map, msd evo chip, ALS. Is there anything else you need to know? Presumed std cams/internals.
Dan
Old Sep 30, 2011 | 07:17 AM
BRAMMER's Avatar
BRAMMER
Just take your car to MSD it's cheap enough and you'll know the car will be bang on.
Old Sep 30, 2011 | 07:31 AM
JamesH's Avatar
JamesH
You won't be able to hold 30psi on greens on a T34 mate!
Old Sep 30, 2011 | 08:07 AM
Paul_RS's Avatar
Paul_RS
I'd did, but I had 8 injectors lol.
I'd do as suggested. Either take it to msd or another reputable tuner to get it set up.
Old Sep 30, 2011 | 08:20 AM
martysmartie's Avatar
martysmartie
I would say you would, almost certainly, as your current calibration won't be mapped for the higher boost pressure!!
Martin
Old Sep 30, 2011 | 08:44 AM
SaphCos4x4_Dan
Tried phoning stu at msd yesterday, but he is a very busy man!
Old Sep 30, 2011 | 08:45 AM
Marc sierra
With that turbo and increasing the boost the current injectors won't flow enough. So you will probably need different injectors and a different chip, since the chip needs to know what injectors it is working with. Best go to MSD then to have it set up.
Old Sep 30, 2011 | 08:48 AM
James @ M Developments.'s Avatar
The green 803s dont flow enough for that sort of boost, they usually peak at around 25-26 and tail off
we can do 55lb siemens packages that will allow you to peak at 32psi and run the turbo flat out to the rev limiter, but it still wont hold 30psi as the T34 compressor is to small and doesnt flow enough air to keep up with the engine at high rpm. they will naturally tail off to around 25psi at the limiter.
Old Sep 30, 2011 | 11:42 AM
ossie cossie's Avatar
ossie cossie
how much for the 55lb siemens packages?
Old Sep 30, 2011 | 11:44 AM
Injectors are £250 a set, chips start at £250 and vary depending on ecu/spec
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
