High reving when iscv is plugged in
Old Sep 15, 2011 | 10:20 AM
carlo's Avatar
carlo
Default High reving when iscv is plugged in
I have a stage 3 saph 2wd running L8 motorsport developments chip runs fine but when you plug the iscv in it revs to about 2.5k what causes this i have cleaned it but made no difference
Old Sep 15, 2011 | 10:51 AM
shaunp's Avatar
shaunp
It sounds like it could be knackered mate, did you have a problem with it before you took it off to clean it? and what did you clean it with?
Old Sep 15, 2011 | 10:53 AM
shaunp's Avatar
shaunp
also have you adjusted the tick over at all as when your adjusting it your supposed to leave it unplugged adjust it then plug it back in!
Old Sep 15, 2011 | 12:25 PM
martysmartie's Avatar
martysmartie
It's not "knackered", clearly it's being told to open by this much by duff info being sent to the ECU, I would look toward the TPS calibration.
Base idle is adjusted when the engine is up to temperature, all electrical equipment switched off, and then with the valve disconnected, set the idle speed, when plugged back in the idle speed should raise momentarily then drop again.
Martin
Old Sep 15, 2011 | 04:16 PM
carlo's Avatar
carlo
I dont know what it was like before i just bought the car & the lad had just fitted L8 to it he said he fitted the tps properly with a volt meter i will try set the idle thanks
Old Sep 15, 2011 | 04:25 PM
D16PJM's Avatar
D16PJM
have the wires been swapped around to run L8
Old Sep 15, 2011 | 04:28 PM
martysmartie
If L8 you will need a PF09 TPS, as well as swapping the outer two wires, the output should INCREASE with throttle, for reference.
Martin
Old Sep 15, 2011 | 04:31 PM
D16PJM's Avatar
D16PJM
Martin
Yeah i had a similar problem with mine and it was the wires on the tpf wasn't swapped, run fine without but when plugged in revved to around 3k, thats why i thought i would mention it.
Old Sep 15, 2011 | 05:02 PM
carlo's Avatar
carlo
Im sure he did say the wires were swapped around , what colour should the tps be ?
Old Sep 15, 2011 | 05:05 PM
D16PJM's Avatar
D16PJM
don't go by colour, should have pf09 on it
Old Sep 15, 2011 | 05:09 PM
carlo's Avatar
carlo
i will text the lad again & confirm what he did when he fitted the l8 he said he set theh tps with a multimeter
Old Sep 15, 2011 | 05:14 PM
D16PJM's Avatar
D16PJM
just check to see if the wires have been cut and rejoined
Old Sep 15, 2011 | 06:05 PM
Paul_RS's Avatar
Paul_RS
You can take the pins out, so it may not have just been cut and rejoined....
Old Sep 15, 2011 | 06:07 PM
carlo's Avatar
carlo
He said he turned the plug around ? must have filed the lugs down i will check 2 moro
Old Sep 15, 2011 | 06:20 PM
martysmartie
It's still wrong, as it will still have the wrong TPS!
Martin
Old Sep 15, 2011 | 06:27 PM
carlo's Avatar
carlo
he fitted a new pf09 mate sorry i forgot to ad that
Old Sep 15, 2011 | 06:47 PM
v man's Avatar
v man
Zee Germans are coming
was the base idle ever set after swapping the bits to l8
personally new saff = set up straight way for piece of mind
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
