ARP stud and nut kit
Sep 12, 2011 | 05:52 PM
i'm gonna put my new engine back together but i've got a head that's too much skimmed already and because of that i need to use a multilayered headgasket (have to figure out compression ratio for thickness)
i want to use this with a arp stud and nut kit on my 200 block now have i heard from some people don't do this because block will crack and other people say that nothing's wrong with a stud and nut kit
what is th best to do use 1 or use standard bolts with a multilayered headgasket?
Sep 12, 2011 | 07:08 PM
if you go for a multilayer then you will need to make sure the block is 100% flat also
what sort of power you after
the small turbo escort cosworth head gasket is the best to go for other than multi
standard head bolts are more than fine for big power
i would just use arp bottom end kit
Sep 12, 2011 | 07:57 PM
i have just got a arp kit for mine, was advised away from standard bolts as mine are lifting the head under load! streching i think
Sep 12, 2011 | 08:10 PM
Quote:
Originally Posted by
Cilly-jey
if my memory serves me correct carl norris of nms uses standard head bolts on his monster 3dr with no issues
i had them on my old 400 and a bit bhp 2wd saff with no issues
Sep 12, 2011 | 08:11 PM
Cilly-jey
plus standard bolts are non stretch anyway
Sep 12, 2011 | 09:34 PM
Standard bolts are stretch bolts mate
v man
Thats correct, he uses them up to a fairly high bhp!
Sep 13, 2011 | 06:37 AM
If the head has been skimmed to much you could be getting into all sorts of problems m8
Steve
Sep 13, 2011 | 06:54 AM
carl dose use standed bolts on lot of his stuff i neally whent that root but going long studs as will be 450-500 horse with gas
Sep 13, 2011 | 07:17 AM
I used arp when i rebuilt mine running 355bhp with no problem, as said above make sure both surfaces are perfectly flat.
Sep 13, 2011 | 07:49 AM
Moonstone Steve
Steve
wich problems then??? if the compression ratio is back to standard there are no problems
Sep 13, 2011 | 07:50 AM
siscossie
do you drive it for a long time already with stud and nut kit also with an cometic mulilayerded headgasket?
Sep 13, 2011 | 07:53 AM
do you drive it for a long time already with stud and nutkit?
Sep 13, 2011 | 08:41 AM
The engine has done 4000miles now with no problems, took it to noble motorsport they put it on the rollers and gave it a once over.
Sep 13, 2011 | 04:59 PM
Paul_RS
oh shit didnt think they were
Sep 13, 2011 | 05:05 PM
Arp stud and nut... And a yb611 headgasket... No probs what so ever on mine...
Sep 13, 2011 | 05:14 PM
you wont have with wot your running tho matt
think its up 400 + people have had probs. i ran standerd bolts at 400 horse fine
Sep 13, 2011 | 05:42 PM
going for standard bolts thanks
Sep 13, 2011 | 08:33 PM
royRS
Valve seats can and have been known to fall out due to a lack of material around that area.
Steve
Sep 14, 2011 | 08:09 AM
material enough on that area so much is it not skimmed
Sep 18, 2011 | 01:53 PM
I rebuilt my engine with standard head bolts and my 205 block cracked, got hold of another 205 block and used ARP stud and nut kit and was all good after that, I would have thought using studs and nuts its better as you are spreading the load more evenly as you torque the head down...
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
