twin 40's or webbers for a 2.0 pinto sierra
have a sierra here which was a 1.6 pinto
swapped engine till a 2litre pinto
but pinto neve came with carb so im using a 1.6 carb an the car is being starved of petrol
anyone got a good set up till cure this?
set of twin 40's or 45's
or webbers like DGAS setup?
45's for the extra bite which is whats going on my mk2
Dgas better than the dgav fitted to the 2 litre!
Even better still is the 40 dfi 15 i think its known as- the upgrade for the 3 litre Essex boys.
None too common, but the one to look out for.
As damo says, 40's too small for the big ports on that engine. Needs 45s! I have both!!
Thanks
Weeksy
Thanks
Weeksy
Thanks
Weeksy
Thanks
Weeksy
I would be looking for 300 for the 45's dude.
Just so you know, as these are competition carbs, they don't have the choke gubbins like most of the others. Not really an issue as a couple of stabs with the throttle will wake them up from cold, but just so you know.
No manifold or linkages, just the carbs dude
Thanks
Weeksy
Thanks
Weeksy
nico12
Dec 31, 2015 04:42 PM
Adam Graham
Sep 6, 2015 06:04 AM
