zvh wont rev
Old Feb 15, 2005 | 07:33 PM
reds2rst's Avatar
reds2rst
Default zvh wont rev
hi all just fitted a 2.1 zvh engine in to my s2 before i had a harvy gibbs built 1.6 cvh and i think that was much better! the zvh wont rev out as well, any one else had this problem? the zvh motor has just been set up on the rollers and made 240 bhp!
Old Feb 15, 2005 | 07:52 PM
r5jame5's Avatar
r5jame5
you cant beat harveys 1.6 cvh i went for a 2.1 before then i had a chat with harvey and he said he could buid me a 1.6 as quick and reliable . i wouldnt go back to a zvh now it seemed lazy compare 2 my new engine
Old Feb 15, 2005 | 07:57 PM
reds2rst's Avatar
reds2rst
i wish i had stuck with the 1.6 now!
Old Feb 15, 2005 | 09:06 PM
DazC's Avatar
DazC
That is a characteristic of the ZVH. It can be addressed with a different stroke crank and different length rods at a large expense.
The power restriction is the head, not the bottom end by the way. The only advantage is an increase in torque lower down which is a by product of having the longer stroke crank.
The CVH has a shorter stroke which will allow it to rev a lot more freely.
If you compare the power graphs of the 2 engines, you will find that the CVH produces peak power higher up than the ZVH if the spec of the 2 engines is pretty close.
TPM961
Jan 15, 2018 10:50 AM
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
