fans switch
Right I have a s2 rst. I'm have trouble with car gett up to running temp but fan won't cut out once its cooled down changed fan switch for a 92 degree jus to see what the fan does. It went right up to the n mark in norm fan cut in cooled it right down to half way then temp stayed the same with fun still running and not cuttin out. If it a wiring fault would it only go back to the fuse box? Car is on mfi and stranded fan for now till I sort this prob out
Had a fiddle with the old switch bloody thing fell apart lol got a 88 degree one in now seems to switch fan off only if I rev the engine I might have a suspect water pump should I get a motor craft one or a after market one ok? Oi creations will be seen u soon mate tryin to track down a fan for my grs
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
