2 stage boost control
Years ago a friend of mine had a pink RS Turbo which had a switch which made it have 2 levels of boost. Does anyone know how this would have been done?
can you not use electronic boost controller you can have dif levels boost with one them i had one on my impreza years ago
You simply fit a switch in the Amal earth line which goes to the ECU, have this on my car, when closed the Amal of course functions as normal and when open the Amal has no power so it's the same as disconnecting the plug on the top of it and hence you run lower boost!
Martin
Martin
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
