Cars & Parts Wanted. Need a specific car or part? Ask in here!! Starting a topic requires you to have purchased a gold membership.
T3 wanted
Old Feb 20, 2011 | 01:50 PM
Rikochet's Avatar
Rikochet
Default T3 wanted
T3 or hybrid wanted for my xr3i - Zetec Turbo conversion. Must be in good order.
Also looking for Megasquirt kit (v2 or above), rear disc conversion and a front mounted intercooler.
Old Feb 21, 2011 | 07:57 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
hi mate, got a spare T3 with the RS Turbo i bought yesterday.
Its still attached to ERST manifold, with actuator etc and compressor housing looks new however the rear oil seal needs replaced. £50 if any good to you, i'm not far away either.
CheeRS
Old Feb 21, 2011 | 12:15 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i have a 4wd cosworth turbo, just the same as a stage 3 turbo bar the 360 degree thrust bearing.
i'm after £150 for this as it has a collins actuator with barely used spring installed and modified bracket to keep good clearance from the radiator.
i also have a custom down pipe so it clears all ancillaries and maintains good flow, perfect for the 3 bolt housing, with lambda boss 2.5" pipe.
this will be an additional £100
minimal movement in shaft as expected from journal bearings, nothing more.
can do a deal with postage for all the above if you like, ran the same turbo on my zvh peaking at 23psi, ideal for ZT/zvh circa 300bhp
cheers
sean
i have a video of this running in car, no smoke etc.
moesin2005
Jan 23, 2022 06:28 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
rog
Aug 30, 2015 05:32 PM
Ben26
Aug 27, 2015 08:56 PM
adriansaleem
Aug 3, 2015 11:21 AM
