Aftermarket Management Advice
Iv got a S2 ZVH and I am trying to find what management people would rcommend and wher to buy from. Short and sweet, any help much appriciated. Cheers
Fucking bell ends!!
lol
It's standalone management just like any other and is as good or as bad as the mapper.
It can be baught DIY and assembled yourself but much easier to buy a prebuilt one.
No downfalls what so ever, can do everything that any other management can do and is far cheaper.
I work as an instrumentation engineer for a multi billion pound company where I put systems together as for measuring and calculating flow, level, pressure and temperature. I have a first class honours degree in Electrical and Electronic engineering. As part of this, my thesis was on engine management.
I have built and mapped many engines in my spare time, on various aftermarket management systems. I also understand and can map - from scratch - certain modern OEM ECUs like Bosch Motronic which are several orders of magnitude more complicated than the most sophisticated aftermarket ECU.
I have no commercial interest in any system so my views are purely objective, based on experience and education.
It's my opinion that Megasquirt can't easily be beaten by other systems unless you have specific requirements such as fly by wire.
Rick
Proof is a strong word, but I will attempt to justify my commen(t).
Rick
Rick
FPMSL! well said that man!
Hello Rick,
I would not compare MS2 to Ford EECV or many modern factory ecu's.
MS2 is fantastic for the pricing - but in standard form does not even provide for
fully sequential fuel injection. It is a batch fire arrangement.
MS3 has come a long way, but still not close to some factory EMS.
However, factory management systems are not all that easy to map - unless on has the
correct tools. Same goes with the Cosworth management. I have programmed the old Cosworth ecu's - a bit of understanding required as they use hexadecimal (00-FF) for mapping values.
For the self mapper (like Karlos) the MS systems are fantastic. Low cost and relatively easy to map. The mapping software is quite user friendly.
These were used for many racing engines in the late 80's (I am aging myself
Perry,
may I draw your attention to this from the post above:
With regards to sequential, it may only have two injector drivers as std, but the software support is there. One of the first things i did on my old CVH was put in Jean's peak and hold 4 channel injector board. Very easy add on and you now have 4 channel seq.
However, i have never needed it on the engines I've mapped. The control over large injectors is superb - std CVH's on grey's that cruise at 1.1 and idle where ever you want them, with excellent response. There is the potential for more economy and off idle response with seq but most people wouldn't notice it.
Rick
Rick
Hi Rick,
I am not trying to argue with you. I agree that many factory ecu's are very sophisticated and impressive. However, you cannot say that these "factory ecu's are several orders of magnitude more complicated than the most sophisticated aftermarket ecu."
This is just not a valid statement. The Pectel SQ6M12, and Motec M880 are just 2 examples. These are aftermarket ecu's that professional race teams use. Costly yes, but certainly a step up from the Bosach Motronic system.
1.1 is as said the fuelling in Lamda.
Oh sweet... Maybe MS2 might be a wise move in the future then... How easy is it to map? Is it literally like you see the pro's doing with a laptop on the move, adjusting fuel tables and spark advance etc etc?
Oh ic now, 1.1 in lambda!
Wicked, better add that to the ever growing list eh?
I know you managed to convert Jonnie from OFAC to MS2, so maybe i'll hitch a ride in his sometime and then go for it!
Relating to the original post: Figure out your budget, find a tuner, and then figure out what is best for you
Wonder why Richies will happily cruise so lean?
