Mondeo caliper spacer kit
if your fitting the 3mm spacers you need for the mk3 calipers with the st170 disks.
all youe need is the old bolts from the mk3 and 3mm worth of washers.
have a look at my 4x4 thread.
I used that guy off ebay too...
Karlos is about right i think, my spacers are his "early" ones made of steel - his "later" ones were alloy iirc. But they are around 12mm thick from memory and you drill the mounting holes out from 10 to 12mm!
