Do fuel accumulators have to mounted upright?
Wye Valley Hardcore
As title really, do they have to be upright, or can they be mounted on their side?
I want to mount mine like this;
and was wondering if it would work correctly?
(I want to keep it as I had custom braided lines made up to keep the accumulator and don't want to buy new lines. Plus I think the accumulator looks quite trick in the fuel line.)
I think it will be fine mate, essentially they are a chamber with a spring and piston to maintain fuel pressure when the engine's off and to smooth fuel flow. No reason why they wouldn't work up side down either.
Rob,
Rob,
Wye Valley Hardcore
That's what I thought, Rob. It's just a chamber with baffles and a diaphragm to hold pressure when the fuel pressures off. I just didn't want turning it on it's side to mess the spring system up.
155lee
Sep 6, 2016 11:10 AM
