Enngine not turning over...TICK
Hello all.
After doing some rebuilding a friends engine, when we go to turn it over to check for a spark, it just Ticks and doesn't turn.
We've tried another starter, but this has not helped.
Is something draining current? maybe the alternator? (as we have replaced the orinal item with a sierra one which was 2nd hand)...
The battery is fully charged.
Many thanks in advance
Austin
Austin
if the battery has been on the car whilst its had its rebuild then a battery may appear fully charged ie a charger will show it as fully charged but one or more of the cells may have broken down.this results in the battery only holding charge in the working cells.
Originally Posted by Austin16v
Hello all.
Hello all.
sound like might be engine seized as this is what one of mine done when it seized up thought it was starter changed it done the same
Engines not siezed. It turned over about 5 times before starting to play up, and the engine is fresh.
Sounds like its deffo the battery then.
doesn't sound like a machine gun, it just ticks once.
Thanks for your help.
the tick is more likely to be the solinode on the starter. dead batterys/poor coonections often have enough power for that but no enough for the starter itself.
ive had both of the above dead battery and crappy connections on separate occasions. check them both to be sure
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
