S1 problem running when i get hot, Help PLz
Hi,
Just built up my S1, but have a problem getting her to run right.
I just wanna get her going, so i can drive her to a Tuner.
The problem is this,
Is start prefect, on the button when cold. runs for 3 or 4 Min's, then die's out and stops.
It will restart but takes an age, and when it gets going it sounds like is only running on 3 cyl. Over fueling i think TBA.
Also if i plug out the Grey plug on the meter unit it runs great, but is way over fueling, kicking out black Sut.
Any one any pointers on what i could be?
could it be the sensor on the meter unit?.
or a sensor that send it its signal?
This is a pic of the plug i take out: and she runs good bar sut when hot.
I think, from reading about here, it controls the fuel going to injectors, and defaults to open when unplugged, hence the way over fueling.
Any help would be great thanks..
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
