will not boost
Old Feb 6, 2011 | 08:53 PM
rs_turbo_ant's Avatar
rs_turbo_ant
Default will not boost
been lookin on the site to find my answers but couldnt,
probley here this a lot my car will not boost its a s2, go to put my foot down and it just pops and bangs not long put a new intercooler on it so may need a set up in my mind or clutch just wanted to here your thoughts any help will b great
cheeRS
Old Feb 6, 2011 | 09:21 PM
Jimmyc's Avatar
Jimmyc
Boost leak maybe?
Old Feb 6, 2011 | 09:27 PM
escortzetecturbo's Avatar
escortzetecturbo
How many psi you running? Might be hitting boost limit if not chipped
Old Feb 6, 2011 | 10:57 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
fueling might no be there for it i wouldnt keep leting it pop and bang mate get it checked over if u dont no. it old be bleed valve fucked or come off?? hoses? boost leak from the pipes ..
Old Feb 6, 2011 | 11:20 PM
liam-rst's Avatar
liam-rst
shit happens
does it have an amal valve, if so check its working
Old Feb 6, 2011 | 11:23 PM
Chopshop85's Avatar
Chopshop85
Mine did that once, The vacuum hose for the ecu had wiggled its way under the heater and got squashed. Just a thought.
Old Feb 7, 2011 | 05:56 PM
rs_turbo_ant
cheers all, no its sitting in the garage wouldnt drive it like that, ill have a look around see what i can find, its chipped holds bout 15psi-ish did run beautifully then it started blowing raspberries.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
