rear arb with mef multi link kit
Old Jan 29, 2011 | 12:48 PM
gus's Avatar
gus
Default rear arb with mef multi link kit
is anyone running a rear anti roll bar with the multi link rear suspension set up
if so any pics
been giving mine some stick today around some b roads and i think she needs arb's to stop a little body roll
Old Jan 29, 2011 | 01:21 PM
muz's Avatar
muz
Wye Valley Hardcore
I'm sure it wouldn't be hard to knock up gus. Probe rear drop links and a custom roll bar.
Old Jan 29, 2011 | 01:53 PM
zippyobrien's Avatar
zippyobrien
Get a civic esi rear roll bar, that's what I'm planning on using. Will bolt in stock position then just use adjustable drop links.
Old Jan 29, 2011 | 02:03 PM
nigel b's Avatar
nigel b
youve seen how mine is done
Old Jan 29, 2011 | 02:51 PM
gus's Avatar
gus
nige i would love your set up
some doofus decided to put a fuel tank in the way
really im just after a cheap and cheerful option til i go for something adjustable
civic one sounds good
Old Jan 30, 2011 | 09:16 AM
Rogeyboy's Avatar
Rogeyboy
How much thicker is the CIVIC item?
I was looking at getting a custom 20mm Rear arb made and using the standard links etc?
Any1 got pics of an aftermarket/uprated rear arb?
Old Jan 30, 2011 | 03:36 PM
DazC's Avatar
DazC
Gus,
Will a a standard rear ARB fit?
I'm on MEF stuff on the rear and use a standard rear ARB connected by some machined clamps to the rear most multi link arms.
Old Jan 30, 2011 | 03:52 PM
gus's Avatar
gus
yeah i guess it would
was thinking it would need to link to both arms in the middle? any pics of yours or spare clamps?
whats the best option to go for on the rear ard then s1, 16i, s2 or orion?
the front is now sorted thanks ti nigel b and his mate using std arb for now
Old Jan 30, 2011 | 04:17 PM
DazC's Avatar
DazC
I came across the rough drawing I did ages ago a month ago. I'll see if I can find it.
I tried running without an ARB but I too found that there was too much body roll, hence why I made the clamps.
I only run across 1 bar either side. Gareth Lloyd's race car only ran like this also many years ago.
I run the standard ARB. A Series 2 roll bar is thicker but you will need the mounting brackets and bushes as well as the link rods.
I'll see if I have any pictures of my set up on Photophucket.
Edit: can't find any! If you're not in a rush, I might be underneath it in about 2 weeks so I'll be able to get some pictures then.
Old Jan 30, 2011 | 04:29 PM
gus's Avatar
gus
yeah im in no rush at all dude
was just me thinking out loud about crossing both bars
well gareth l certainly threw his around a bit
if its good enough for him im sure i will be fine
mint_s2
Sep 2, 2015 08:58 AM
YODI
Aug 30, 2015 01:12 PM
borboyous
Aug 22, 2015 11:17 AM
Alloy wheels and ICE for sale
Aug 16, 2015 07:55 AM
saph in dorset
Aug 14, 2015 10:10 AM
