Dump Valves
Old Jan 30, 2005 | 01:18 AM
fernando_khan's Avatar
fernando_khan
Default Dump Valves
OK im NOT starting a debate weather or not dump valve or chatter is the better sounding...just want to know what kind of dump valves people like to have that sound and perform nice....atm i have a le mans which not only sounds bloody shite but i think it has a leak ....
so what is the best soundin?? and what is the best performing??
1 person said to me baileys is the best one...but had no reason..
cheers
p.s. would be great if anyone had any sound clips or video clips of a rs turbo with some nice sounding exhausts and bovs...
Old Jan 30, 2005 | 02:35 AM
Rallyesport's Avatar
Rallyesport
Get any twin piston type, it will not leak. If you want a different sound, get one with a venturi/trumpet.
Old Jan 30, 2005 | 07:22 AM
M K's Avatar
M K
as above
Old Jan 30, 2005 | 06:24 PM
S1 Barkham's Avatar
S1 Barkham
Yeah, i have a Blow Off Valve on mine lol, it's tunable to suit your needs
Old Jan 30, 2005 | 08:25 PM
fernando_khan
what do you mean by tuneable?? tighten and loosen the spring?? how much difference can you make to the noise by tuning it??
cheers
Old Feb 1, 2005 | 09:37 AM
escortrsmatt's Avatar
escortrsmatt
i think the best would be a Bailey DV26.No idling problems or running problems!sounds sweet aswell.there is a new one out with a `trumpet` on it which may sound different.
Old Feb 1, 2005 | 10:19 AM
a/rs/e's Avatar
a/rs/e
I currently have a Turbo Smart Supersonic dumpvalve. If its noise you want and as above tuneable then, Id say you cant go wrong with this one. Had the first Bailey twin piston d/v, just didn't have the same effect. Must admit when I first put it on I was disapointed as had spent £200 odd quid for a dump valve and was quiter than the Bailey, however after taking it to PTS for a tune they got the bloody thing screaming at me, so as I said if you want to be noticed then you cant go wtong with this. Gota ask yourself if you can warranty spending that sort of money on one.
Old Feb 1, 2005 | 03:47 PM
S1 Barkham's Avatar
S1 Barkham
cheers
You put washers in the top of it to put more tension on the spring
Old Feb 1, 2005 | 07:29 PM
AKRS1's Avatar
AKRS1
baileys dv26 for me
Old Feb 4, 2005 | 04:46 PM
Speedy Gonzalez's Avatar
Speedy Gonzalez
baileys dv26 is the tits best dump valve 4 the rst
Old Feb 4, 2005 | 10:47 PM
AKRS1's Avatar
AKRS1
I do have one question does any get a unsual feeling of the car pulling to the left when building up big boost and then slowly taking your foot of the throttle. I know it sounds stupid but ive had 2 rsts and both have done it. It might be that my engine mounts have had it.
Old Feb 5, 2005 | 07:54 AM
MK5RST's Avatar
MK5RST
Torque steer check ur bottom bushes and replace them with stiffer items and the engine mountings, and get it tracked once u put new bushes on, you will never eliminate torque steer on a big power front wheel drive car tho!
Old Feb 5, 2005 | 09:03 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
I had a bailey one on the S2 and never had a problem with it.
Old Feb 5, 2005 | 03:43 PM
fernando_khan
my car has loads of torque steer aswel...been told wider tyres and a strut bar with polyflex's make a big difference to standard....but im planning on 230 bhp with that power i think a quaife diff will only be the thing to stop it going all over the show.
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
