RWD ZETEC POWER
Well ive finaly decided on a 2ltr zetec for my xr2, n mite be gettin a trust electricals one,ive been lookin at the 190+bhp jobbie with the alpha management..
just a lil question.. il hav 2 change ma fuel tank on ma car wont i.. n wat to?
if you try the fiesta-centre they stock a continential fuel tank as abroad they had the opion of a cfi mk2 hence the tank comes fitted with a swirl pot as std for your fuel injection.
mind you some people dont rate them
and would rather fit a xr3i (mk4) or similar swirl pot in to a std tank
check this out for further info
http://www.quantums.info/zetecinMk2.htm
fuel cell would be a good 1.. and seing as the floorpan will be wripped out for the tunnel may aswell channel the fuel lines in. wud want a fair big'sh tank tho.. asi expect it to gobble up fuel.
at pointing out the prop shaft..
I knew that i was just testing
well if thats the case i would it be possible to get a new tank and cut and weld a small tunnel into it for the prop?????
having never attempted such a conversion i dont know how big the rear diff is or how far it would need to sit under the petrol tank
JK12
33
Apr 26, 2021 12:09 PM
slammedorion
15
Nov 1, 2015 07:17 PM
