dizzy cap
Old Sep 29, 2010 | 08:23 AM
davecosworth's Avatar
davecosworth
IM BACK
Default dizzy cap
is it poss to fit a 4x4 dizzy cap to a 2wd distributor and do i need to change the arm as well just want to be sure as my new leads have arrived for a 4x4 not 2wd not long put a new 2wd cap and rotor arm on
Old Sep 29, 2010 | 08:41 AM
Paul_RS's Avatar
Paul_RS
Arm is the same across the range as far as i know?
Old Sep 29, 2010 | 03:42 PM
The caps go on either, dizzy is the same, but if using straight cap on 2wd clearance can be tight to the rear of the inlet plenum.
Old Sep 30, 2010 | 06:38 AM
davecosworth
IM BACK
yeh i got a 2wd manifold with 4x4 plenum and spacer
15
Oct 7, 2015 03:43 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
20/20 vision
Sep 28, 2015 03:03 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
