sierra cosworth rad over heating problem
Old Sep 21, 2010 | 02:46 PM
mulla's Avatar
mulla
Default sierra cosworth rad over heating problem
last week a hose burst on my cossie 2wd ,i had a wireing fault on the fans now fixed and hose replaced,now the problem is when i boot it the gauge for the temp reading goes right up not in to the red tho about 1cm ,then it comes back down again the fan kicks in as normal and brings the temp down,before the hose burst it was fine sat in the middle diddnt realy move ,im thinking theres trapped air ,how would i remove it and what do you think it may be.
Old Sep 21, 2010 | 04:51 PM
martysmartie's Avatar
martysmartie
More likely the gauge making you paranoid due to there inaccuracy! So long as the fans cycle ok then it's fine.
Martin
Old Sep 22, 2010 | 04:22 PM
Just ensure your de-gas pipe is nice and clear from the turbo(return) and it will get any air out that might be there.
Though I agree most likely nothing to worry about so long as fans are cooling it ok don't worry, if you still have the std deflector plate in the front bin it.
Old Sep 22, 2010 | 04:33 PM
RS500/364's Avatar
RS500/364
If you know someone has a pectel or collins monitor can check the running temp on your car !
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
