3 Door ABS ECU
Old Sep 12, 2010 | 06:51 PM
Dearo's Avatar
Dearo
Default 3 Door ABS ECU
I need to mount the ABS ECU bracket in my 3 door 1.6 shell, but I can't see where abouts in the drivers footwell it should be mounted.
Therefore could someone kindly post up a picture of one in situ, please
Old Sep 13, 2010 | 05:27 PM
Dearo's Avatar
Dearo
Anyone help ??
Old Sep 13, 2010 | 05:36 PM
stickertone's Avatar
stickertone
mate, unless someone's got a stripped shell it'd be hard to take a clear pic without removing the trim and bottom half of the dash.. even then its tucked right up behind the wiring and relays....
Old Sep 13, 2010 | 07:44 PM
toff's Avatar
toff
Old Sep 14, 2010 | 07:28 AM
Dearo's Avatar
Dearo
Originally Posted by toff
Bloody hell, is it up that high
Old Sep 17, 2010 | 01:54 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the 3 door has it in the upper dash not the footwell like the facelift 90 spec cars do
Old Sep 17, 2010 | 03:55 PM
martysmartie's Avatar
martysmartie
What he ^^ said above the ECU I should think same as 2WD saff, 4x4 had ECU mounted under dash.
Martin
JK12
33
Apr 26, 2021 12:09 PM
Vincereese
Sep 17, 2015 10:34 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
Adam Graham
Sep 6, 2015 06:04 AM
