indicators
Old Sep 9, 2010 | 09:04 AM
raycov's Avatar
raycov
Default indicators
why has my indicators stopped working and also hazard warning light i have checked the fuses ok escort rs turbo 1989 s2
cheers
Old Sep 9, 2010 | 01:01 PM
martysmartie's Avatar
martysmartie
Can you hear a rapid clicking at all? If so it will be the hazard light switch as it doesn't get mush use coupled with the switch being old the beeswax used inside dries up and so the contact isn't good, you can take it apart to clean or just get a new switch, this effects indicators as well as all power goes through this switch.
If nothing at all then I would be checking the flasher unit/relay, or the power feed.
Martin
Old Sep 9, 2010 | 07:36 PM
raycov's Avatar
raycov
cheers martin there is no clicking at all where is the flasher unit relay
Old Sep 9, 2010 | 08:36 PM
rst230bhp's Avatar
rst230bhp
flasher relay is on the back of the stork
Old Sep 9, 2010 | 08:42 PM
Oranoco's Avatar
Oranoco
Had this in mine, are the fans dead as well? If so you need to look at the fuseboard and the relays there
Old Sep 10, 2010 | 08:41 AM
raycov's Avatar
raycov
the fans work so where is relay on the stork and which relay is it in the fuse box
cheers
Old Sep 10, 2010 | 11:25 AM
raycov's Avatar
raycov
took the stalk off checked red wire to the indicator and its getting power but dont work there is no feed to the hazard warning light but when i bridge the red wire it works hence no live feed any ideas
cheers
Old Sep 10, 2010 | 05:32 PM
martysmartie
Theres a red wire which goes to the hazard switch, the indicator stalk connector will have a black wire which is SWITCHED live as is the case with switched feeds on Fords on this era.
Check that you have +12V on one side of the fuse as well with ignition ON.
Then check the contacts for this fuse, firstly that they are not corroded and then that the wire is connected to them ok underneath.
Don't know on Escorts but I strongly suspect the flasher unit will be behind the dash like other Fords of the age, you don't need to worry though as you don't have power to start with!
Martin
steve.rst
Mar 15, 2016 08:01 AM
Rammer46
Sep 18, 2015 08:31 AM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
