Rattly disc any ideas??
Old Jul 2, 2010 | 08:38 AM
sambo170588's Avatar
sambo170588
Default Rattly disc any ideas??
morning people,
right i have a 1.6 fiesta zs tryed gettin some help of the zsoc but to no avail, my problem is i have rattly disc and by that i mean everytime i go over small bumps/potholes/grates etc theres a realy annoying rattle now i fitted the brakes myself and i have checked them they all sound bck together properly theres jus the slightest bit of play between the disc and the end of the driveshaft, but everything works fine, i suspect that they may be warped or that my wheels needs balancing i dunt no weather any of these could be the problem, i did have the wheels balanced not long bck but due to the **** state of the roads i suspect that they may be buckled, any help would be much appriciated, cheers
Old Jul 2, 2010 | 08:52 AM
RichieST's Avatar
RichieST
Hub nut done up tight?
Old Jul 2, 2010 | 09:03 AM
sambo170588
will check em rich, im goin from nottingham to skeggy tomorrow so could do with it sorting today realy lol ill havva look soon mate and let you no how i get on
Old Jul 3, 2010 | 05:24 PM
sambo170588
nuts definately tight its got some king of locking nut onit, checked all wheel nuts to make sure there tight and where, so i took the wheel of checked all the brake calliper bolts etc etc ALL TIGHT, so any ideas???? cheers
Old Jul 3, 2010 | 05:31 PM
RichieST's Avatar
RichieST
Thing is, with the wheels off, the disc will rattle as its the wheel and wheel nuts that hold it all tight. Sure its not something else? Knackered balljoint etc?
Old Jul 4, 2010 | 08:23 PM
It's very very unlikely to be a disc rattling, as you'd have little to no brakes.
I'd look at arb drop links(if fitted) first.
Old Jul 4, 2010 | 08:42 PM
t4 and greys's Avatar
t4 and greys
cosworth gimp
check your brake pads mate
had the friction part breakaway from the metal backing once and only noticed it due to a rattle similar to yours mate
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
timsrs
22
Sep 24, 2015 08:14 PM
rogerxr3i
Sep 13, 2015 06:56 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
Rizlablue
Sep 6, 2015 09:58 AM
