helpppppp!! please
Old Jun 30, 2010 | 05:15 PM
sambo170588's Avatar
sambo170588
Default helpppppp!! please
hiya people,
im kinda stuck we have a ford focus 1.4 2002 model engine keeps missing underload, its had new coil,temprature sender unit, and new plugs, i thinking it might be electrical, maf? lambda?? any ideas??
Old Jun 30, 2010 | 05:57 PM
I'd start by changing the fuel filter unless done so recently, then check the co.
Old Jul 1, 2010 | 04:03 PM
sambo170588
thanks for the reply tabetha why would you say its that i no i say its boggin down 'underload' but i wudnt have throt that would cause it to behave like it is its not spluttering or anything its jus like hitting and missing when u poot your foot down, cheers
Old Jul 1, 2010 | 04:14 PM
It could do, there are a number of things it could be such as BOSCH plugs, these can cause the issue, as they can track chronically in zetecs, the leads can cause it, on the earlier zetecs leads ford used silicone grease inside the plug caps where it slid over the porcelain.
I suggest first take the plugs out and look at the porcelain part and see if it has any lightning type black streaks on it, as this is tracking, and is another thing to look at.
phil_focus's Avatar
phil_focus
have the plugs been gapped correctly?
would be worth getting a fault code reader on it.
Old Jul 2, 2010 | 08:33 AM
sambo170588
sorted guys it was the leads, well atleast it wasnt anything major thansk for replys
Old Jul 2, 2010 | 11:29 AM
phil_focus's Avatar
phil_focus
good 8) glad it was an easy fix
jay simpson
Mar 19, 2010 10:37 PM
M3.coupe
Dec 10, 2009 09:24 PM
fatboyz
Mar 18, 2008 09:05 PM
