Has anyone converted a 1.8 diesel to 1.8 td
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
get your self a cheap full tdi car, mot failure, scrapper etc and swap everything over.
the pump immobiliser can be easily bypassed at the pump end to save a lot of hassle removing the "snap-head" bolts that hold the immoblisier box/solenoid in place
I'm doing this on one of my Escort Vans. How do you bypass the immobiliser?
Si
Ive done this on a transit is there an ecu for turbo or dont they have them cheers.
on my pump, theres a stop soleniod on th epump being controlled by a little back box, change ths stop solenoid for one off ebay (about Ł7).
this still retains the immobiliser on the keys and the starter
What about the turbo is it just bolt on or does it need the electrics connecting cheers.
