xr3i efi cut out
Old Jun 24, 2010 | 06:02 PM
slimwynn's Avatar
slimwynn
Default xr3i efi cut out
hi all i'v got a problem wandering if anyone can help last night started the car up started fine drove down the road and the car cut out no miss fire or poping just cut out like u just turned the key off so i was thinking fuel so got towed to the garage put a tenner in then got towed again still nothing so when at home i took a spark plug out thinking it could be electrical on taking it out i thought the spark plug would be wet after towing it thinking it would be throwing in fuel and not burning it but the plug was bone dry,now after a few tests i'v checked the fuel and theres fuel to the fuel rail and checked for a spark but theres no spark so i'm stuck where to look now has any one got any ideas cheers
Old Jun 24, 2010 | 07:45 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
what year is the car ??
if its mk5/6 common fuse box
Old Jun 24, 2010 | 08:10 PM
I'd check the ecu fuse, as this will knock out both fuel and spark if blown, don't know where it is on your car though, it may be attached to the main control relay itself, this supplies 12+ to the injectors and ecu at the same time.
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
