Escort RS turbo squirting oil out of bleed valve?
Old Jun 21, 2010 | 09:02 PM
DanFR147's Avatar
DanFR147
Default Escort RS turbo squirting oil out of bleed valve?
I've recently purchased a 1989 Escort RS turbo. According to its history was a previous show winning car winning 1st prize in its class at the Ford Fair in 98,99 and 2000. The car in running a stage 1 chip, which i have disconnected as i am a standard car type of guy!
My plan is to put the car back to standard over time. At the moment once you take the car over 4500/5000 rpm starts bellowing blue smoke out the exhaust. On closer inspection, the metering unit is full of mobile 1 and a big puddle which has squirted out of the bleed valve. The oil was every where, it had even filled the almo valve and the pace intercooler.
I have cleaned all the pipes, valves, intercooler and bottom of the metering unit out but problem keeps coming back.
Can you please help solve this problem? What should i do? Where should i go?
Old Jun 21, 2010 | 09:14 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
turbo failure!!
Old Jun 21, 2010 | 09:36 PM
DanFR147's Avatar
DanFR147
Mmmmm, sounds expensive! What do i do? Can i have mine reconditioned? Or pick up a second hand one?
Can anyone recommend a contact?
Old Jun 22, 2010 | 07:08 AM
I use the turbo centre, 01924 404112.
Old Jun 22, 2010 | 05:30 PM
Alvyn's Avatar
Alvyn
check the engine breather's not blocked
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
jay030787
Aug 17, 2015 06:16 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
