Get hot on high speed runs
Old Jun 20, 2010 | 03:21 PM
essexRSTSouthend's Avatar
essexRSTSouthend
Default Get hot on high speed runs
What could cure my car getting hot when doing 130 plus?
Old Jun 20, 2010 | 03:25 PM
jaiscossie's Avatar
jaiscossie
Run it without a bonnet
Old Jun 20, 2010 | 03:28 PM
essexRSTSouthend
Good idea.Just really annoying when have to slow down due to heat.Front mount dont help air flow .
Saaamon's Avatar
Saaamon
Surely your not sitting at 130 for that long
Old Jun 20, 2010 | 03:30 PM
essexRSTSouthend
That depends saaamon lol.more like off the clock speeds.
Old Jun 20, 2010 | 03:34 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
twin fans on a switch maybe mate.how hot does it get? water pissin out the bottle hot?
Old Jun 20, 2010 | 03:39 PM
essexRSTSouthend
Already on switch dude.I reckon the fans dont spin enough.Need better ones.Bottle holds.Water levels fine.Only got her back on road yestoday.
Old Jun 20, 2010 | 03:41 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
its maybe air locked? but only over heats when the pressure builds right up.
Old Jun 20, 2010 | 03:44 PM
essexRSTSouthend
Yes could be worth a try.Give it good flush..
Old Jun 20, 2010 | 03:56 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
keep it around 120
twin fans in front blowing and std one pulling
new rad (alloy) lower stat
car set up ??? could be running mega lean/rich creating heat
Old Jun 20, 2010 | 04:15 PM
essexRSTSouthend
got alloy rad.might buy another fan as yot stated.Car does need set up by fuel was spot on but since then its had a new dizzy with no markings and stage 3 head.Running standard 12Degrees until set up.Thanks for your help.
Old Jun 20, 2010 | 06:28 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
cool mate itl prob just need set up
when i started mucking about with megasquirt i had it way lean on cruise and the mani was glowing off boost lol
this caused the temps to rise prety quick
failing this the twin fans push/ pull setup
Old Jun 20, 2010 | 06:33 PM
rstdave's Avatar
rstdave
Get the fuelling checked.....never had problems with mine getting hot whatsoever when the car is moving!
Done plenty of 140+ runs and trackdays and on the road mine never got hot, though can't see why you'd want to hold it up there long enough to have it overheating!
Old Jun 20, 2010 | 06:41 PM
cozzy940's Avatar
cozzy940
slowing down
Old Jun 20, 2010 | 07:34 PM
essexRSTSouthend
I have my reasons lol.I normally drive pretty safe.You just get the odd occasions :-p.Ill put the fueling tiny bit up and go from there.Ill put it back to the way power engineering done it.keep you guyr posted.thanks for all your help !
Old Jun 20, 2010 | 07:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Agree 100%!
Mine never gets over 95deg even when hitting 6000-7000rpm in 5th @ 24psi
Everyone going on about fans are way off the mark, fans do not cool the engine when your moving (unless your doing 10mph lol). You get 1000x more airflow from moving than any fans will ever be able to give lol
If your hot it's because either your cooling system is not perfoming well (blocked rad, hoses, etc..), your lean (fuelling needs sorting), or your head is not seating 100% to the block (not much you can do about that easily).
Old Jun 20, 2010 | 08:06 PM
essexRSTSouthend
I hope its not the head! was done up correctly with arp bolts.I think its running lean.As the fueling is back one whole turn on metering unit (black unit on right side).so ill turn it back to the way it should be and cross fingers that helps.
Old Jun 20, 2010 | 08:13 PM
essexRSTSouthend
just to let you know,doing speeds of around 70 to 90Mph,the temp stays just below midway.
Old Jun 21, 2010 | 12:26 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
is the thermostat opening properly?
is the front mount restricting airflow too much?
my zvh on 23psi of boost doesn't get too hot at all, infact above 50mph and it's cool as you like.
Old Jun 21, 2010 | 02:02 AM
essexRSTSouthend
yes mate,that been tested and works.keep you posted .
Old Jun 21, 2010 | 03:35 AM
rsmark86's Avatar
rsmark86
i had this on my car it was the water pipes round the wrong way on the heater matrix so had an airlock in it.... but since then ive got a airtech rad/fmic/msd fan switch kit and 82 degrees thermostat and genuine ford temp sender and it never goes above half way now and when at them speeds my gauge reading is dropping off the bottom lol
Old Jun 21, 2010 | 04:31 AM
tasos77's Avatar
tasos77
rs turbo from Greece...
do you remember the correct fitting way for the heater hoses?
Old Jun 21, 2010 | 01:35 PM
essexRSTSouthend
Yes i know what you mean.They can get kinked if put on wrong.will also try this.many thanks!
Old Jun 21, 2010 | 01:55 PM
mk1trb's Avatar
mk1trb
Boost Junkie
my estate use to cook under full load, turned out to be a cracked head, but it is normally caused by water system block or underfueling
Old Jun 21, 2010 | 03:10 PM
essexRSTSouthend
Yeah.Had a cracked head in water jacket last year.This a new head,covered less tham 5000Miles.No signs of oil or water mixing.not losing water.air block,fuel issue me thinks.Car runs fine,no smoke or noises.idles fine.In traffic i switch fans on,that stays below mid way.Drove car today,had to put fans on for little while doing 50 to 70 and lots of stops and starts in traffic didnt help.
Old Jun 21, 2010 | 04:05 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
All this talk of fans etc, they aren't relevant at 130mph. The situation can be improved by looking at airflow to the radiator, but chances are you have another issue.
Old Aug 12, 2011 | 09:19 AM
essexRSTSouthend
Even now the issue stays but not as bad.Had most parts apart,flushed rad and heater matrix and all hoses.fitted new water pump,temp sender,fan switch,new thermostat.heaters work fine. List goes on,even that wetter stuff.is it possible that ive wired the fan switch back to front that would make the fans kick in late? Its the fan switch from msd.sometimes it kicks in midway or before and other times waits until on high normal temp. Dodgy new temp sender?
Old Aug 12, 2011 | 09:46 AM
Karlos G's Avatar
Karlos G
Balls Deep!
As already said above FANS DONT MAKE A DIFFERENCE AT 130mph!!!! lol
How do you know your actually hot? Are you going by the 25 year old temp gauge or do you have a decent aftermarket one as you might not actually be hot at all?
Old Aug 12, 2011 | 09:59 PM
MO' BENT RIMS's Avatar
MO' BENT RIMS
did u bleed the system bud? and turn the fuelling up\\/? wire a direct switch aswell. btw your a nutter doing 30 and looking at the temps lol . i had mine off the clock but dont have the balls to look at the dials lol . i just no it because it does 130in 4th gear ish .. i have it in 5th on full boost lol
Old Aug 17, 2011 | 06:34 PM
essexRSTSouthend
Took motor to jano,metering unit dancing about.was running on pretty much air lol.So might explain the heat build up.So trying to source another metering unit.Jano set the mixture up,went out for spin,came back and was running lean again with 10minutes!
My rad is restrictive from air flow due to the standard bumper.But i understand the physics of air flow but the strange thing was having the fans on a manual switch when on motorway helped,dont know why.ive always had to keep heaters on to help cool down quicker too.
The temp sender is new,so id expect the dial will move up and down as the sender tells it too but might be worth a shot trying a aftermarket dial.
So yeah looks like it was a major lean issue.keep posted.
Only reason look down is my other half goes oo it getting hot lol.
Old Aug 17, 2011 | 06:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
my first thought re-reading this old thread was engine running lean. my tiny rad keeps even my engine cool at high speeds/loads.
Old Aug 17, 2011 | 07:20 PM
essexRSTSouthend
Yes mate.cross fingers it sorts it.
Bailes1992
Sep 3, 2015 02:17 PM
Sheepdisease
Aug 30, 2015 09:11 PM
Adam-M
Aug 26, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
