2.1 zetec cvh head
hi guys
not to sure if this has been posted about before,
i have the 2.1 cvh engine ( zetec bottom end, standard rs turbo head)
would i be able to get more power out of the engine if i put on a zetec head so it would be a full zetec engine? or an st170 head?
any help apprieciated
cheers
cheers
as i said on the other post you can put the zetec head on but your compression ratio might end up to low and you will probably need to have some oil galleries un blocked don't try using st head as you'll run into more problems for not a lot of gain
right ok, im kinda new to fords and zetecs so whats the difference between the blacktop n silvertop, n im amsuming tha the silvertop should jus bolt on, and jus need to clear some oil galaries n stuff
JK12
33
Apr 26, 2021 12:09 PM
TPM961
Jan 15, 2018 10:50 AM
