Nomad 3 gauge vent holder
Old Jun 19, 2010 | 04:19 PM
kermitt's Avatar
kermitt
Default Nomad 3 gauge vent holder
Got the metal one from Nomad with the engraving.
Should there be a clip to hold it in at the top of the dash cos mine sticks out a bit but not too badly.
Also there is a big gap about 10mm between the adjuster knobs and the panel itself almost as if something is missing or should I just stick on the Lockwood dial kit.
Don't think I will be able to get the old lighting strip off anyway cos it looks stuck on with something and don't really want to break it by taking it apart.
Old Jun 19, 2010 | 08:05 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
i have the same problems with mine... I think i will buy an other from burtons, they look better than metal from nomad
Old Jun 19, 2010 | 08:10 PM
mr_joe0606's Avatar
mr_joe0606
I bought one from burton and it was a metal one to. Unless they have started makeing plastic ones. Best ones i have seen are from auto specalist all the gauges are angled towards the driver. They are quite pricey dho
Old Jun 19, 2010 | 08:43 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
Burtons buy from nomad mate as they are the same, only ones that are different are the ones from autospecialists
Old Jun 19, 2010 | 10:46 PM
kermitt's Avatar
kermitt
Had a look on AS website and could not see the holder anymore but I know it used to be there cos I contemplated buying it at the time. Wish I had TBH.
Old Jun 20, 2010 | 12:07 AM
tasos77's Avatar
tasos77
i thought that the burton was plastic! I haven't seen triple gauge holder at AS site! Only the gauge holder behind the steering wheel!
Old Jun 20, 2010 | 07:42 AM
EssexMikeSi's Avatar
EssexMikeSi
i had the metal one once and found i had to keep pushing it back in as it would keep popping out. I also appreciate my air vents too much when the weather is warm so i fucked it off and now have a double pillar gauge holder and my 3rd gauge is in the blanking panel to the left of my steering wheel. Im sure i used to see plastic ones that were the whole unit of where the vents are. Probably not made anymore.
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
dirty-diesel
Oct 3, 2015 07:59 PM
Steve Escos
Oct 1, 2015 06:57 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
