diesel sierra more power lucas cav
Old Jun 19, 2010 | 03:44 PM
1968unclefester's Avatar
1968unclefester
Default diesel sierra more power lucas cav
hi all new on here
my daily car is a sierra 2.3 diesel ( puegeot engine )
its got the lucas cav pump and i want to open it up a bit for a bit more grunt ive done bosh ones before but not sure about these
ITS A TIDY CAR WITH NICE HIGH DIFF AND TYPE'9 BOX SO MAY GET A 24V I KNOW ABOUT SOON
chears TIM
Old Jun 19, 2010 | 07:52 PM
On the side of the pump you should see a hexagon shaped cover about the size of a 50p piece, behind this is the locknut and screw for the governor, so tweak this a bit, think it's counter clockwise for more fuel, obviously if belching soot just back off a bit.
Old Jun 19, 2010 | 08:05 PM
1968unclefester
tar
i think ive got it , mine had a plastic cover over so took it off and found round lump with hex inside is this what you mean or is it the one thats dirty with the small bolt in middle
see pic , chears TIM
Old Jun 20, 2010 | 09:47 AM
It's the hex with the smal bolt in the middle.
Old Jun 20, 2010 | 10:35 AM
1968unclefester
superb i presume its remove hex nut then wind out adjuster a bit
is there a set amount of turns ?
DO YOU YOU KNOW IF ITS GOT TO GO IN OR OUT
CHEARS FOR ALL YOUR HELP TIM
Old Jun 20, 2010 | 02:12 PM
I am not 100% sure as ages since I did one, just take large cover bit off and have a gander, I would move around 1/8 a turn at a time.
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
Bighandsuk
Sep 2, 2015 05:23 PM
