Escort G3 RWD C20LET wiring issue
Old Jun 19, 2010 | 06:36 AM
cozi500's Avatar
cozi500
Default Escort G3 RWD C20LET wiring issue
Ive recently come across a wiring issue with my C20LET management loom, the fuel pump relay will not power the fuel pump. The relay is getting power as it should but has no ground actuation, so the live feed will not switch to ground, on terminal 3 on the ECU plug. Ive tested the loom twice now and found no fault, all is as it should be, even the screened earths. For those of you out there who done this type of conversion maybe able to help me. Ive had a new ECU and even had that tested, and thats ok, new fuel pump works ok in another car. ive looked aroun on the net, some say it maybe the crank sensor???????? but im not sure, can anyone please help me.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Cameron
14
Aug 9, 2015 06:28 AM
