How to calculate compression ratio?
Old Jun 18, 2010 | 10:17 AM
Fobos's Avatar
Fobos
Question How to calculate compression ratio?
Hello everyone! I've disassembled my CVH 1.6 (with Hemi (89SM) head) engine. So i decided to tune head: to lighten valves, to make chamfer 30* and to polish the head for compression improvement. But there are some questions - how to measure compression ratio? how to calculate what compression rate is needed? because the piston is with displacer and i am not sure if my cylinder head wasnt polished before.... how to define it? Thanks for your answers.
Old Jun 18, 2010 | 12:12 PM
Sp3no's Avatar
Sp3no
Look at the links in the technical gudes at the top of the technical page, it will explain all in there, its not straight forward
Old Jun 18, 2010 | 02:00 PM
Fobos's Avatar
Fobos
Sorry, but I can not find what I'm asking in this topic, please put a link if this question was discussed.
Old Jun 18, 2010 | 02:32 PM
OldDan's Avatar
OldDan
http://www.rbracing-rsr.com/compstaticcalc.html
Really should be done with the engine built and parafin!
Old Jun 18, 2010 | 04:14 PM
Sp3no's Avatar
Sp3no
http://www.motorsport-developments.co.uk/stus.html
Here you go fella, bloody good bit of reading here
Old Jun 21, 2010 | 08:12 AM
Fobos's Avatar
Fobos
Guys, i know how to calculate compression rate, the main question for me is to measure the volume of combustor because the piston is with displacer?
Old Jun 23, 2010 | 07:11 AM
Fobos's Avatar
Fobos
Someone calculated the combustion chamber at all on this motor with these pistons? I really need help ... : (
Old Jun 26, 2010 | 07:47 AM
JonathanJ's Avatar
JonathanJ
The only way I have used to measure the volume of a raised crown piston is to use some plasticine ( raided my kids play box lol ) and make a mould of the piston crown at tdc , then remove this and measure it volume using the syringe and paraffin , then you can subtract this from the clearance volume . hope this helps .
Old Jun 29, 2010 | 10:19 AM
Fobos's Avatar
Fobos
Just yesterday I thought about this way, thanks, I will try
Old Jul 6, 2010 | 12:22 PM
Fobos's Avatar
Fobos
I measured, received 17 cm3 Not a bit too much? Did anybody measure a volume of the camera in the hemi cylinder head? It looks like it has to be about 50 cm3
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
