Does this look the same as l8?
Old Jun 14, 2010 | 10:08 PM
XR_Cos's Avatar
XR_Cos
Default Does this look the same as l8?
I got this from a lancia dedra a while ago, thinking of using it on my 2.1 zetec turbo providing its basically an l8 and can be chipped as such.
From the pics i found it looks the same, got it with loom, all sensors, injectors, throttle body etc! So hopefully i can use it!
Old Jun 14, 2010 | 10:47 PM
boost mad's Avatar
boost mad
It looks similar to me, although cant remember exactly what mine looks like inside.
If you dont get any other replies, pm me tomorrow eve and i will open my L8 up and take some pictures for you !
Old Jun 14, 2010 | 10:49 PM
XR_Cos's Avatar
XR_Cos
Awesome, thanks
Old Jun 15, 2010 | 06:22 AM
oldford's Avatar
oldford
The Lancia and Ford units are almost the same. There are small differences in the wiring.
Old Jun 15, 2010 | 07:09 PM
XR_Cos's Avatar
XR_Cos
What sort of differences?
Old Jun 15, 2010 | 08:38 PM
jamie rst's Avatar
jamie rst
Ask Jano on oddkiddcreations.co.uk he might be able to help you mate
Old Jun 16, 2010 | 08:01 AM
oldford's Avatar
oldford
Lancia and Ford weber-marelli ecu's are very similar. Most of the sensors and actuators are the same and on the same pin.
Big difference from a diagnostic standpoint is that the Lancia ecu's all have a serial link, through which you can read codes and data, where the Ford unit only have a blinking led.
8V turbo
Not real boost control, but an overboost (0,1-0,2 bar) at full throttle - with an overboost light.
8V turbo cat
Check engine light
16V turbo
Check engine light + 2 map sensors - 2-bar and 3-bar
16V turbo cat
Check engine Light + Wasted spark
Old Jun 18, 2010 | 11:19 AM
XR_Cos's Avatar
XR_Cos
So I should be able to have it chipped by the usual cossie tuners then? It was from an 8v I think.
Old Jun 18, 2010 | 11:21 AM
XR_Cos's Avatar
XR_Cos
I'll see if he can help, thanks
Old Jun 18, 2010 | 11:39 AM
martysmartie's Avatar
martysmartie
It looks like an L8, Fiat along with others as said used exactly the same management system being it's Italian anyway, the turbo Dedra even has a Garrett T3. Obviously the software is different but apart from that I think there the same.
Martin
Old Jun 19, 2010 | 09:32 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Once a pectel board is fitted the software will be the same and enable tuning. I have a Lancia delta ECU on one of my customers cars that i bought from Sardina on a holiday i took some time out to visit a breakers yard.
Old Jun 19, 2010 | 09:38 PM
XR_Cos's Avatar
XR_Cos
Awesome news, i`ll be in touch regarding the phase sensor fittings.
